Old 06-01-2013, 02:37 AM   #1 (permalink)
Eco Sol
Shortie771's Avatar
Quick Question on MPGuino Install
Got my MPGuino a few days ago and finally have the time to install it tomorrow. Everything from what I have read seems pretty straight forward. Attach power (always on), good ground, vehicle speed sensor and injector. What confuses me is that what I read says to unplug all of the injector connectors and use the one with NO voltage. Does that mean use a negative wire or does that mean that 1 of my 4 injectors will literally show no voltage when I put the key into the "run" position?
Sorry for the stupid question, but I would just rather have everything figured out before I start running wires and pulling my dash apart.
Thanks,
Andrew
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
Old 06-01-2013, 04:41 AM   #2 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
It means that select/pick any injector you want to connect, there should be two wires. Now test those two wires and take the one which has no voltage.
I have made my connections near ECU or instrument cluster so there is only one wire per injector.
Meelis
http://mpguino.wiseman.ee/eng - get assembled mpguino from here!
The Following User Says Thank You to meelis11 For This Useful Post:
Shortie771 (06-02-2013)
Old 06-02-2013, 04:03 AM   #3 (permalink)
Eco Sol
Shortie771's Avatar
Thank you for your help. I successfully managed to install the MPGuino this afternoon and it seems to be working fine. After a few tanks of calibration everything should be great. I only have 1 issue with this thing. I payed extra money to get a red one (like in the pictures I've seen) and the one I got turned out to be orange... Kind of bummed about that
CR-Z Current Mods:
Max Sidewall PSI
Old 06-03-2013, 01:01 AM   #4 (permalink)
JellyBeanDriver's Avatar
Who was the vendor for your 'red' MPGuino?
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
- http://www.dschmidt.com/MPGuinoJBD.html
Old 06-03-2013, 01:37 AM   #5 (permalink)
Eco Sol
Shortie771's Avatar
Got mine from here
CR-Z Current Mods:
Max Sidewall PSI
Old 06-03-2013, 03:36 AM   #6 (permalink)
meelis11's Avatar
Diesel
Hi,
It is same screen like in this picture in my gallery.
I am sorry if you are not satisfied with it.
Maybe I should write that on my web that it is more like orange-red, not red?
It is not pure red, little bit orange-red. first I looked too that it is not red, it is orange, but when it is installed in my car, it blends pretty well with other instrument cluster red lights. But I can say that it has best brightness and visibility compared to other red displays I have tested. Much brighter (I have actually turned brightness down in software, otherwise voltage regulator got too hot and it was drawing too much current).
Meelis
Old 06-04-2013, 02:47 AM   #7 (permalink)
Eco Sol
Shortie771's Avatar
Yes, it is a bit more orange than red. I agree the brightness is excellent on it. I really would have liked a true red MPGuino but I'm sure it would have been a bit more dim. Honestly I am just happy that I finally have one and I am not going to nitpick over it.
CR-Z Current Mods:
Max Sidewall PSI
Old 05-08-2014, 02:15 PM   #8 (permalink)
93 Civic - '93 Honda Civic DX
90 day: 39.93 mpg (US)
meelis11
If I buy a kit from you, can I access the computer and edit the program on it?
Old 05-09-2014, 04:56 AM   #9 (permalink)
meelis11's Avatar
Diesel
Originally Posted by yarisyeti View Post
meelis11
Hi,
pm sent. Yes I can give my code for customers.
You cannot connect it directly to computer, you need arduino for programming and then put microchip back to mpguino.
My new version includes ICSP header (you can program microchip in-circuit using programmer) and serial interface pins (you can use serial-usb module)
Meelis
