Old 07-13-2019, 08:50 AM   #1 (permalink)
90 day: 34.37 mpg (US)
How do I remove Gorilla Tape?!
Does this technically go in the How-to section?
I know that many of you have used duct tape on your car, but I doubt that would last long-term. My heater did not work when I was driving from Page to Show Low, which only mattered when I drove through a snowstorm in Flagstaff.
Who needs a heater if there is not a snowstorm?
I made a grill block with marine plastic and I doubt it survived its maiden voyage, although that would have been a five-hour drive.
So, I turned to Gorilla Tape.
It seemed like a good idea at the time!
For a while I was surprised at how long it lasted. At some point I just accepted that it was permanent. If I ever caught up with my projects and finances I could try to figure out how to remove it and make a nice grill block, but at some point I accepted that being behind on projects and finances is permanent.
Then I drove to Phoenix for, as I mentioned elsewhere, a work trip that may never pay for itself.
You know how we say that the factory grill opening is designed for a vehicle driving uphill through Death Valley and pulling a trailer?
Well, I ended up driving 45 in a 55, and running my heater. I need to see if the dollar store has a cheap thermometer because adding engine heat to a solar oven has to make a difference.
Maybe just put cookie dough on a cookie tray?
Can I secure that to the dash?
I looked into removing Gorilla Tape before and did not get anywhere. All that I see now is how to remove the residue.
What did they do wrong that the Gorilla Tape ever came off? I am not worried about peeling off Gorilla Tape and leaving residue.
I am worried about removing the paint!
I finally found one solution!
1. Remove the bumper.
2. Soak it in lighter fluid.
3. If necessary set it on fire.
The guys at work were kind enough to explain how airflow and engine cooling work--after I asked how to remove Gorilla Tape.
One mentioned slitting the tape with a utility knife, which might be all that I need. Then once I leave civilization for places with civilized weather, just patch it with Eternal Tape.
Have any of you successfully removed Gorilla Tape [and its residue?]
Old 07-13-2019, 12:47 PM   #2 (permalink)
I don't know about Gorilla tape, but with duct tape you can turn the force against itself.
"The Flat Earth Society has members all around the globe" -- The Flat Earth Society
Old 07-13-2019, 01:44 PM   #3 (permalink)
Soak through the duct tape?
Old 07-13-2019, 01:46 PM   #4 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
Maybe soak it with xylene? I found that was pretty good for removing adhesive residue...
My current Ecotec project...
My last Ecotec project...
Old 07-13-2019, 02:07 PM   #5 (permalink)
I will add it to the list.
Someone on YouTube said that lighter fluid did not do anything to their Gorilla Tape, but I still think it is the best place to start.
Old 07-13-2019, 02:30 PM   #6 (permalink)
With duct tape, the backing de-adheres [UV] so it peels right off, then use WD-40 or penetrating oil to wipe off the adhesive.
I have used Gorilla glue and I like it.
Old 07-13-2019, 03:15 PM   #7 (permalink)
I don't know about Gorilla Glue, whenever I use it, instead of getting a nice buzz, I insist on sitting wherever I want.
Gorilla Tape uses a different adhesive. I am sure that Gorilla Hot Glue is different still.
I don't think that Gorilla Glue comes off a car easily, either!
I do not want to try to remove the tape down here. I would hate for it to turn into one of my usual projects. I plan on leaving by 05 so that it is below 90° when I hit the hills.
A friend mentioned driving me to my class which would be vastly better than driving in 110° weather with my window down and the heater on.
My heater core was delayed, so I may do this project first.
Old 07-13-2019, 03:42 PM   #8 (permalink)
Heat gun and a shop rag?
Old 07-13-2019, 05:54 PM   #9 (permalink)
A non ferrous buffer pad on a grinder.
Old 07-15-2019, 09:58 AM   #10 (permalink)
I have used GooGone for this. It is an orange based cleaner, that is meant to remove the glue. It won't hurt the paint.
