Old 11-25-2012, 11:06 PM   #1 (permalink)
Joe1234's Avatar
Question How do I update mpguino firmware? No USB port on MPGuino..
I have this version:
What needs to be done to physically wire it to the computer so that I can make firmware changes and upgrades?
I searched and searched. There should be some adapter that hooks up to who knows where so that I can make firmware changes just like I do with a regular arduino..
Old 11-26-2012, 02:31 AM   #2 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
One possibility I suppose is to buy an Arduino board and swap the ROM into it.
Old 11-26-2012, 04:34 AM   #3 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
If you already have arduino, you could use it to program chip.
Problem is that chip in mpguino - it may have programmed without bootloader. Then you need to write bootloader into chip first.
http://mpguino.wiseman.ee/eng - get assembled mpguino from here!
Old 11-27-2012, 09:13 AM   #4 (permalink)
Joe1234's Avatar
Shouldn't there be 4 pins or so that I need to solder or attach a serial to USB board onto so that I can just upgrade it the same way as the regular arduino??
Old 11-28-2012, 10:26 PM   #5 (permalink)
Joe1234's Avatar
Wow. I'm surprised that the procedure for this is beyond the knowledge of the members of this forum. Who else could I ask?
Old 11-29-2012, 02:21 AM   #6 (permalink)
meelis11's Avatar
Diesel
You already made 2 topics about this and got many answers. What else do you want? You could ask directly from seller (dcb?) to get most accurate answer. As I said - you probably need programmer because there are no bootloader - bootloader is little program to write firmware to chip using USB.
something to read:
http://www.ladyada.net/learn/avr/
Old 11-29-2012, 09:16 AM   #7 (permalink)
Joe1234's Avatar
I took the chip out and put it into my aduino UNO. I tried to use arduino v.11 but it wouldn't run on win7 64bit bc it's old as sh*t so I went back to v1.0 and tried uploading it. Of course that didn't work and I got the error:
avrdude: stk500_getsync(): not in sync: resp=0x00
which means it can't communicate with it. I was not surprised by any of this and fully expected it.
All of this is WHY I was asking for specific instructions. Not maybe's and probably's. The real answer would be, "oh yea, I did this before. What you do is <step 1>, <step 2>, <step 3> etc." Messing around for hours with maybe's and probably's = bad. Following proven instructions = good.
