Old 01-19-2011, 09:31 AM   #1 (permalink)
Possible rear bumper mod
Possible rear bumper mod.
If one could remove trunk for spare wheel and bottom part of rear bumper and connect it with bottom cowering plate - it should be efficient and less costly than roof chopping. It would be ideal for sedans with long rear.
Old 01-19-2011, 10:19 AM   #2 (permalink)
Can't have much rise before flow separates there, rendering the effort useless.
Old 01-19-2011, 10:41 AM   #3 (permalink)
Of course you are right. 14-15 " wheel is about 20 in diameter with tyre. So we could have bottom partial kamback 20" length. It is more in length than more of top kamback..
Old 01-19-2011, 10:51 AM   #4 (permalink)
That red curve is too steep and I'm quite sure wouldn't represent an aero improvement over stock.
Old 01-19-2011, 11:22 AM   #5 (permalink)
Ok. That kind of slope in degree we would use ? 10-15 or less ?
Old 01-19-2011, 11:58 AM   #6 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
4 degrees is what the number is around here for the bottom.
I think it's 10-15 on top.
Old 01-19-2011, 02:33 PM   #7 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
That depends on the chassis shape: A fastback or sedan has lowest aerodrag (Cx) around 3°-4°, but a squareback (like the Fiat Idea you used as an example) is better off with a flat rear(*).
(*) If the car already has a Kammback, then it is no longer a typical squareback and a slight diffuser angle may be OK.
On the other hand, race and performance cars have more aerodrag Cx and less Cz (= more downforce) when the diffuser angle is greater than 5°.
Either way, getting rid of, or covering up, a spare that hangs down in the air flow is something to think seriously about.
The Following 2 Users Say Thank You to Piwoslaw For This Useful Post:
brucey (01-19-2011), COcyclist (01-19-2011)
Old 01-19-2011, 09:03 PM   #8 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
That's usually where the muffler is hanging out, too.
-Terry
