Old 06-09-2013, 08:25 PM   #11 (permalink)
Air density from freezing to boiling point of water drops by 25%. Basically that means when you go to those two extreemes you have only 3/4 of the air mass. Atmospheric pressure also drops by 50% at 18k feet altitude.
If you needed 50% of your available manifold pressure to maintain 70 MPH then you would need 100% at 18k feet or everything the engine could produce, not considerating the lower aero drag at that altitude.
Better throttle response will always occur at lower intake temperatures, to the point where temperatures get low enough to prevent proper atomization of the fuel air mixture.
Like the winter when germany invaded Russia in WW2. Try starting your car in 40 below temps (hint 40 below farenheit and celsius are the same temperature).
regards
Mech
Old 06-09-2013, 08:39 PM   #12 (permalink)
ever_green's Avatar
gueff - '19 Mercedes Benz A250 4MATIC AMG
90 day: 30.55 mpg (US)
wow i really liked that operation barbarosa reference but i thought the problem there was engine oils freezing.
back to topic, i noticed some car manufacturers have delibrately designed the intake system for higher temps. im not sure why but i remember reading somewhere that warm air intakes actually imp4ove mpg? my acura for example has much hotter intake temps than my subaru.
Old 06-11-2013, 06:18 AM   #13 (permalink)
Chevy - '07 Chevy Colorado LT
90 day: 20.63 mpg (US)
So far I've been avg closer to 30mpg if I'm not driving crazy, compared to 22 or 23 without out being warmer, reason why it's increased because of the grill block.
