Old 06-08-2013, 05:32 PM   #1 (permalink)
Chevy - '07 Chevy Colorado LT
90 day: 20.63 mpg (US)
how hot is got intake temp
Just wondering if anyone can tell me if 115 is way to warm, scangauge sometimes reads 115°fia. Any help would be nice, thanks, silvercolly07
Last edited by silvercolly07; 06-08-2013 at 05:32 PM.. Reason: said fiat instead if fia
Old 06-08-2013, 09:37 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
have you read the sheet from Scangauge that explains the abreviations?
that's the air temp at the MAS sensor.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-08-2013, 09:53 PM   #3 (permalink)
Insight for life's Avatar
05 Prius (wife's) - '05 Toyota Prius package 5
90 day: 44.32 mpg (US)
Citrus - '00 Honda Insight
Gen-1 Insights
90 day: 60.68 mpg (US)
In my Honda insight I usually shoot to run at 115 to 125 intake temp. yesterday I saw 154* on the intake temp, it scared me so I pulled off some of my grill block. the car still ran fine tho even at idle.
Old 06-08-2013, 11:35 PM   #4 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Dayum - I've been shooting for 150+ F. I usually see around 120 F during the day, and 105 F at night.
Old 06-09-2013, 03:31 AM   #5 (permalink)
EcoModding and having fun
Ol' Honda - '84 Honda Civic 1500 S
90 day: 37.03 mpg (US)
why so hot? mine is running at whatever the temp is outside unless its hot and im driving a little in the city then it rises a bit to like 90 ish. I am thinking about doing a WAI has it helped you guys?
Old 06-09-2013, 09:24 AM   #6 (permalink)
Straight from the manual "fia/cia- intake air temperature - temperature of the air going into the engine. At highway speed, this will typically be a few degrees higher than the outside temperature. At idle or low speed, it may reach higher than the outside temperature due to the low airflow onto the engine and the high under-good temperature warming up."
Old 06-09-2013, 09:54 AM   #7 (permalink)
mcrews's Avatar
In my Q45 I found that to be accurate 100% of the time.
however, in my Kia Sportage, I have seen 140-150. And it has not been over 90 outside and I was driving 55 in the middle of the day.
Not sure what is happening there.
On the same day just moments later it dropped to 105.
ECO MODS PERFORMED:
First: ScangaugeII
Old 06-09-2013, 10:08 AM   #8 (permalink)
MPGuino Supporter
t vago's Avatar
WAIs have helped both my Dakota and my Magnum. The truck gained more dramatic increases in FE, though.
The Following User Says Thank You to t vago For This Useful Post:
aktacoma (06-09-2013)
Old 06-09-2013, 11:06 AM   #9 (permalink)
Lower air density means you can have higher effective compression to produce the same level of power. This means less fuel to do the same work with lower pumping losses. Broad statements about what is best will not cover specifics of individual vehicles. Some will work better and others will not. Best to experiment with your individual vehicle.
regards
Mech
Old 06-09-2013, 07:26 PM   #10 (permalink)
ever_green's Avatar
gueff - '19 Mercedes Benz A250 4MATIC AMG
90 day: 30.55 mpg (US)
mine is usually 5-10'f higher than ambient temps when cruising and 10-15'f higher at idle. On all vehicles I have driven, specially my subaru, lower air intake temps give me better throttle response.
