Old 01-27-2012, 05:54 AM   #1 (permalink)
Improving FC on a Nissan Maxima 99
Hi Guys,
I own a Nissan Maxima 99 V6 3.0 AutoGearbox ( 50k miles only ) and I wish to know if someone of you guys own the same car and improve its F/C.
I already swap the Gearbox Fluids and also using Mobil 1 5W30 Extreme Performance 5W30 oil and also added Militec-1 to the oil to reduce the friction on the movable parts. Tires as Brand New Michelin XM1+ 15 Inces 205/55 and always with 32 psi on each tire. Always using 87 octane fuel.
Please let me know your concerns.
Thanks in Advance,
Rafael Valente
p.s. : Sorry for my english, I`m btw from Rio de Janeiro.
Old 01-27-2012, 07:51 AM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
f/c means? fuel consumpstion?
You can increase the tire preesure.
I run 42 psi on an Infiniti Q45 and have for over 100k. but on a 55 series tire there is plenty of sidewall to absorb the road.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 01-28-2012, 04:14 PM   #3 (permalink)
42 I think that is very high, I shall try 36 at least.
I will remove the Mud Flap from the side of the car try to improve aerodynamics.
Regards!
Old 01-28-2012, 05:50 PM   #4 (permalink)
mcrews's Avatar
Mud flap really wont make a lot of difference.
Seach the 'tire pressure' threads, I can promis you 42 is no big deal.
Also, check a nissian site ( I am a moderator on FRESHALLOY . COM) and see if the ecm and tcm have a 'learning ability'
On the 02 Infiniti Q45 the ecm (engine brain) and tcm (transmission brain) will adjust over time to how you drive.
I drive pretty easy so the car's brain adjusts for better mpg instead of speed.
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-29-2012, 07:15 AM   #5 (permalink)
Great Forum,
I`m going to register, how to help each other... Thanks!
