Old 10-21-2008, 06:38 PM   #21 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Firing order is not the same as movement. Pistons move in pairs, but spark plugs don't fire in pairs. More here...
Old 10-21-2008, 10:38 PM   #22 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
Originally Posted by thefirebuilds View Post
one should consider pulling the rods and pistons will unbalance the crank causing excessive wear on the other moving components. I would assume that the production versions of these are simply forcing valves open to reduce friction resistance, obviously the cylinders aren't removed when disabled in those cars.
chevy uses this lifter deactivation
Name:	cylinder deactivate valves.jpg
Old 10-21-2008, 11:23 PM   #23 (permalink)
Hydrogen Nut
Ptero's Avatar
Smart Car ForTwo Pure - '08 Smart Fortwo Pure stripped
90 day: 51.35 mpg (US)
BMW 750iL V12 - '90 BMW V12
90 day: 26.4 mpg (US)
Wildfire 250C - '08 Shandong Pioneer 250C
THE LAST WORD: Engines are compressors
Back in the early 70s, I came across an abandoned mining claim once where the old timer had converted a straight 4-cylinder engine to obtain compressed air for his mine. I took a look at the plumbing and stared at it for the longest time, trying to make sense of it. He'd cut off the front of the exhaust manifold that collected the exhaust from the first two cylinders. And he'd brazed shut the hole to allow the remaining rear part of the manifold to carry away exhaust gas. He pulled the spark wires off the front two plugs and just left the plugs in. He'd taken the front part of the exhaust manifold, turned it around and brazed an iron pipe to the hole he'd cut in the manifold, and ran the pipe to an air tank!
I describe this to illustrate that the internal combustion engine without combustion is an air compressor - and can be quite a good one if you delay the exhaust valve from opening until top dead center (TDC). The old timer couldn't figure out how to delay his valve so he got by on reduced compression.
Truck drivers, on the other hand, turn their diesel power plants into air compressors all the time. The Jake Brake shuts off the injector fuel flow and uses electric solenoids to delay the exhaust valve opening timing. By compressing air with the engine cylinders, you can slow down a 40-ton truck pretty good.
So forget about the easy fix myth for ecomodding engines by stopping the spark or fuel delivery. You gotta pull the piston. Otherwise you're running an air compressor - and that's not going to give you the mileage gain you're looking for.
Ptero
Old 10-21-2008, 11:29 PM   #24 (permalink)
Hydrogen Nut
Ptero's Avatar
Back in the early 70s, I once came across an abandoned mining claim where the old timer had converted a straight 4-cylinder engine to obtain compressed air for his mine. I took a look at the plumbing and stared at it for the longest time, trying to make sense of it. He'd cut off the front of the exhaust manifold that collected the exhaust from the first two cylinders. And he'd brazed shut the hole to allow the remaining rear part of the manifold to carry away exhaust gas. He pulled the spark wires off the front two plugs and just left the plugs in. He'd taken the front part of the exhaust manifold, turned it around and brazed an iron pipe to the hole he'd cut in the manifold, and ran the pipe to an air tank! When he cranked it (it had a magneto), it fired on two cylinders and ran pretty good.
Ptero
Old 10-22-2008, 06:20 PM   #25 (permalink)
roflwaffle's Avatar
It's only an air compressor if there's a restriction on the exhaust or intake.
Old 10-22-2008, 06:57 PM   #26 (permalink)
It's an air pump if there's no restriction...
Old 10-22-2008, 08:20 PM   #27 (permalink)
Puddles - '95 Geo Metro LSI
90 day: 39.52 mpg (US)
Spec Miata - '91 Mazda Miata Club Racing
Scooter - '05 Honda Metropolitan
Monstro II - '99 Dodge Ram 1500
Kassia - '01 Mazda Miata LS
Precious - '97 Chevy 3500 Silverado Dually
I bet you could do this in a VTEC or other sliding / adjusting cam engine by making the secondary lobe wholly round on the exhaust side, so when it slides over it just opens the exhaust port. You could knock a 4 down to a 3. VTEC engines are pretty easy to adapt to a flip-switch situation, rather than driving off of RPM as they come from the factory.
The cost will be in the head.
How is a ZETEC engine? is it variable cam timing or a moving cam like in a Mazda CCV?
Old 10-22-2008, 10:29 PM   #28 (permalink)
roflwaffle's Avatar
An air pump involves changing the pressure AFAIK, which doesn't happen for the most part w/ an unrestricted engine.
Old 10-22-2008, 10:35 PM   #29 (permalink)
I haven't accessed data re: pressure changes while motoring dead cylinders. I'd have to think, though, that there was a reason the OEMs all adopted valve shut-off strategies. You are saying that isn't necessary? Then they added cost and complexity where they didn't need to.
Old 10-22-2008, 11:57 PM   #30 (permalink)
roflwaffle's Avatar
Emissions y0. Even though they can just shut off a bank and ignore oxygen sensor output for the deactivated one, the cat will favor HC compared to NOx at leaner mixtures, so they need to keep the exhaust stream at stoich. I suppose they could use some funky exhaust routing to do this but it's easier just to deactivate valves.
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
The Cars GM Needs To Make Big Dave General Efficiency Discussion 66 01-05-2009 03:18 PM
Home Brew Challenge for Electric Geniuses (make a DIY electric motor controller) WaxyChicken Off-Topic Tech 42 08-19-2008 01:05 AM
News: Maryland legislators may require cars to make some noise MetroMPG Fossil Fuel Free 9 02-22-2008 08:51 AM
DIY: Make a PVC Catch Can for your PCV System TomO DIY / How-to 0 11-14-2007 03:30 PM
