well let me tell u ...
u will get some more power from the a6... but u will lose that mileage but not by alot...
i am not accurate with my mileage... but when i had my b18a1 in my hf ... i filled up the tank which is 10 gallons i believe? 24$
went down to omaha... a 4 hour drive... i arrive with over half a tank of gas which is probably 6-7
so wat im trying to say is... if you put a good mileage motor, but yet alot more stronger... it takes less load, and by load i mean less gas useage to get up to speed. which willl get you to your destination without burning as much fuel as it would be needed in the original car.
Sorry, new users are not permitted to post links in their signatures.
