Old 10-15-2008, 10:17 AM   #1 (permalink)
Civic - '98 Honda Civic DX
90 day: 41.44 mpg (US)
Idle at 20mph
Theres a side road I usualy take on my way to work...minimal stops, and minimal traffic.
The speed limit is 25mph. I found yesterday that my car will hold 20mph when I take my foot off the gas. The engine drops back to idle (like Idle in drive at a stop light) It shifts to 2nd gear at about 15mph under slow accleration.
Is this a more efficent than keeping the throtle open to hold 25mph? Because the RPMS drop from like 1,500 to 800ish
Old 10-15-2008, 10:21 AM   #2 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.64 mpg (US)
You'd have to test that one on your own, probably... But I can only imagine it helps.
Old 10-15-2008, 10:57 AM   #3 (permalink)
F150 - '97 Ford F150 Lariat
Taurus - '02 Ford Taurus SE
the 73 - '73 Ford Thunderbird
the race car - '95 Ford Thunderbird LX
The Brick - '98 Buick LeSabre Limited
put it this way......anytime you are not touching the gas, you are using less.
Old 10-15-2008, 06:52 PM   #4 (permalink)
I figured that but I didn't know if vaccume pressure would affect this any.
Old 10-15-2008, 07:39 PM   #5 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
An old roommate of mine had an old Chrysler M-Body with a 3-speed Torqueflite that could be coerced into idling along in 3rd, at around 25mph. Really nice in city driving.
Old 10-15-2008, 09:05 PM   #6 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Binger -
I think you have found a comfortable sweet-spot for your Mirage. It's especially nice that the road's speed limit makes your speed look "normal". 20 MPH is probably the drop-dead-bottom-practically-idling 5th gear speed for my car too.
I wanted to find some gear ratios for your tranny, but all I could google were these URLs :
1991 Mitsubishi Mirage
Mitsubishi Mirage pictures 1991 models
CarloSW2
American Solar Energy Society
Old 10-15-2008, 09:21 PM   #7 (permalink)
theres a good sized following for these cars but most people swap 4G63T's in to them so no one knows what the stock specs are
Old 10-16-2008, 12:42 PM   #8 (permalink)
Hello,
For me, idling in 3rd or 4th gear (15-20mph) returns great mileage: 40-50mpg. Fifth gear is a little tougher to hold a speed on level ground at idle.
Throttle position is everything in FE. If I can hold the TPS to 19-20 (my xA displays 12TPS at idle when my foot is of the pedal), then my FE is much better than if it is at 21 and above.
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Disconnected Idle Air Control - for lower RPM after a cold start Lazarus EcoModding Central 19 04-15-2011 03:50 PM
Idle Speed Adjustment '89 Metro SirKeats DIY / How-to 7 02-08-2010 02:23 PM
Altered Idle Speed After Performing EOC Tango Charlie Hypermiling / EcoDriver's Ed 20 11-19-2008 12:41 PM
Engine Idle i_am_socket EcoModding Central 3 06-06-2008 04:03 PM
