Old 08-10-2015, 07:43 PM   #1 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
My Veg oil experimentations..
Running on Veg oil explained
After 1900 miles of trouble free WVO shenanigans in the Octavia, I thought I'd pop up a cheeky little guide on what to consider..
https://fuguttycars.wordpress.com/20...ic-vegetables/
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
The Following User Says Thank You to 320touring For This Useful Post:
niky (08-11-2015)
Old 08-11-2015, 12:32 PM   #2 (permalink)
Love the set-up! Been meaning to do something similar, only I can't get my hands on enough oil...
The Following User Says Thank You to niky For This Useful Post:
320touring (08-11-2015)
Old 08-20-2015, 07:19 PM   #3 (permalink)
Team m8
Have ordered proper sock filters for the WVO today- hopefully be here by the weekend!
Old 08-29-2015, 03:47 PM   #4 (permalink)
Team m8
got the sock filters for the WVO set up, 10micron on the Right, 5 Micron on the left
The bottle on the right contains the oil as bought, the bottle on the left is after the 10 micron filter- good improvement
niky (08-29-2015)
Old 08-31-2015, 06:41 AM   #5 (permalink)
Maybe you could consider supplement the veggie oil with some fish liver oil, which I assume might not be so hard to get back there. White fish usually retain the major part of its fat content in the liver.
The Following 2 Users Say Thank You to cRiPpLe_rOoStEr For This Useful Post:
320touring (08-31-2015), niky (08-31-2015)
Old 09-02-2015, 03:40 PM   #6 (permalink)
Team m8
TO be honest, for me getting the oil is not an issue.
I have a tame man who bulk buys it and de-waters it, then filters to 50 microns
I just buy 100L at a time, and process to 10 microns
Old 09-16-2015, 04:39 PM   #7 (permalink)
Team m8
As part of the general going over I did the usual fluid level checks.
Coolant/brake fluid all spot on, jowever the Oil level was ABOVE maximum..
This is a sign that the WVO is getting past the piston rings- and collecting in the sump.
The car is still running well, no obvious running issues and no MPG drop
Obviously this is not ideal! I took the most sensible path possible, based on the fact that it is a supercheap beater -
I dropped some oil out the sump and topped it up to max with fresh oil.
Over the last 4000miles it appeared to be approx 500ml- will keep an eye on it.
Old 09-16-2015, 05:08 PM   #8 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Hehe, saw this and responded on TDIClub as well.
Be careful about leaving this WVO in your sump, it will polymerize and hurt your engine due to lack of lubrication. Best idea is to do a complete oil change at 3000 mile intervals.
I'm not coasting, I'm shifting slowly.
Old 09-16-2015, 05:33 PM   #9 (permalink)
Team m8
Aye, did some reading on it-will keep an eye on it- reckon the 3k changes may be the way forward
Old 10-05-2015, 08:31 PM   #10 (permalink)
Alternative Fuels Addict
I've run heated wvo in my '02 Ford 7.3 Powerstroke since 2004. It does work but it does require attention.
I strongly suggest using a centrifuge to filter the oil. PA Biodiesel Supply : Waste Vegetable Oil Cleaning : Biodiesel Centrifuge : Motor Oil : Water Removal : WVO Filtering : Dewatering Centrifuge : WMO Filtration Units has some good units at much better prices than I paid back in the day.
By the way, I've gotten as much as 367 miles to a gallon of diesel using heated wvo. That means I started and stopped the day driving on "store bought" diesel and spent most of the time running on free, filtered and heated veg oil.
I'm glad to help in any way I can... including the mistakes I've made. Oh, and I'm in the chemical business so this is right up my alley.
The Following User Says Thank You to ToddT58 For This Useful Post:
ME_Andy (10-05-2015)
