Old 01-08-2016, 09:49 PM   #11 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by ksa8907 View Post
As far as the engine revving while coasting in neutral, i would start by measuring the fuel consumption when idling (stopped) and when coasting.
this!!!!
Get a scanguage and do this test in about 5 minutes.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
MobilOne (01-09-2016)
Old 01-08-2016, 09:52 PM   #12 (permalink)
mcrews's Avatar
it's easy to get fixated on something like this....had a tarsus that did the same thing.
But there are probably three other things you could do to get better mileage.
half of a quarter of a gallon OVER 1 hour is nothing.
maybe you can reduce the rpm in half, but it doesn't use twice as much gas to run 1500rpm (IN NEUTRAL). And honestly, how much time do you really spend coasting....
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-08-2016, 10:25 PM   #13 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
^That.
Also, based on my Wrangler and an expected 200,000mile life, I can actually buy a brand new Prius (inclusive of fuel and insurance) with the fuel savings. My Prius is actually 'free' as compared to using my Wrangler on a regular basis. I bought a used Prius so it actually 'makes' money. In fact I could even say I bought my Fiat brand new and the used Prius and got free fuel, with the fuel money from the Wrangler.
4x4's are awfully expensive to run. US figure will be a bit more SUV friendly I suspect.
Old 01-09-2016, 06:59 AM   #14 (permalink)
FJ - '12 Toyota FJ Cruiser
that is a great thought. I have been considering a ScanGauge.
Old 01-09-2016, 12:26 PM   #15 (permalink)
mcrews's Avatar
there is a function call "fuel per hour" or "consumption per hour" that shows an instant continuous reading.
So one day you can coast down a regular hill and stay in gear, and the next day you can coast the same hill in neutral.
The you can see the difference.
Remember, the gauge is giving you a gallon/hour reading so you have to divide by the guestimate of the number of minutes you actually coast.
God Luck!
(ps you can buy a scangauge from this site!!)
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-09-2016, 01:30 PM   #16 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Please clarify. If coasting in neutral at 65 mph & 1500 rpm is 400 mpg, wouldn't 750 rpm in neutral at the same speed be 800 mpg, which is half the gas and double the mileage?
Old 01-09-2016, 02:52 PM   #17 (permalink)
mcrews's Avatar
Same way that coasting at 65 at 1 rpm doesn't double the mileage from the 750 rpm. It's not a simple math equation. I would actually assume it is based on what is required to rim the engine. Engine load, gearing etc.
the issue, imho is consumption of fuel during the brief moments of coasting TO THEN justify a hack that might have unintended consequences.
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-09-2016, 03:36 PM   #18 (permalink)
mcrews's Avatar
The bigger issue is: is it worth it?
Ecomodding makes sense on a older car.
But in newer cars, when there is so much pressure on manufacturers to I crease corp mpg, do you REALLY think that they have left MPG's on the table?
Look at all the trouble dodge went to to achieve class leading mpg on a truck! The actually have an active dispersion to lower the body 1" to improve aero at speed.
I would bet that Toyota has a reason for the rpm NOT to drop.
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-09-2016, 10:48 PM   #19 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
It may simply be to throw enough BTUs down the exhaust pipe to keep the cat running. Look back here:
http://ecomodder.com/forum/showthrea...ing-20338.html
My car failed CA emissions testing recently, and I'm confident my hypermiling had a direct relationship to the problem.
The failure was because some of the drive cycle monitor readiness flags hadn't been set since I cleared the check engine light/malfunction indicator light in October. Since then, I'd driven 800 miles, but the catalytic converter driving cycle is 15 minutes at speeds between 60-100 kph, and I hadn't done that in 4 months.
The next day, I warmed the car up, driving it enough to add 100 miles since the test failure. The car passed smog testing. Examination of the retest shows cleaner emissions after driving the car a distance at speed.
I drove the car 900 miles RT to/from SoCal last week, and the cat stayed lit, between 1101-1185 degrees F. When I do my normal low speed P&G, cat temps are 285-550 degrees F, too low to light the cat.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
mcrews (01-10-2016)
Old 01-20-2016, 12:41 AM   #20 (permalink)
Liberty Lover
j12piprius's Avatar
rpm ~ no significant effect on mileage
I'm interested in your tests of coasting at 1 rpm, and how they support your theory that coasting rpm makes no significant difference to mileage. Likewise, please post some evidence that 3000 rpm, for example, is no worse for mileage then 1500 rpm, and whether this applies to gas use when idling at a stop, as well as when coasting.
