Old 12-14-2017, 04:25 PM   #31 (permalink)
In town here natural gas surcharge is about $20 per month.
Out in the country where there is gas is around $25.
Last time I checked each million BTU of gas was about $5.
1Mbtu of propane is about 11.25 gallons.
roosterk0031 (12-14-2017)
Old 12-14-2017, 05:18 PM   #32 (permalink)
Do the electric companies cut the rates in the winter if you use enough?
Here during winter the first $68 (500 kwh) is $0.136 kwh, next 200 kwh drops to $0.114 ($78.90/month) then $0.077 so almost half price. Summer rate is $0.152. Not including any connection charges, just charges per KWH.
Old 12-14-2017, 08:23 PM   #33 (permalink)
Most places the rates go up the more use you use.
That goes for electrical, gas, water at least every where I have been.
Old 12-15-2017, 06:01 AM   #34 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Mine:
Customer Charge $8.21
Initial Block (<= 100 kWh) $0.108068 per kWh
Tail block (> 100 kWh) $0.147735 per kWh
Power Miser Credit $1.37
Burlington is powered entirely by local renewables, and was the first city in the US to do so.
Old 12-15-2017, 10:45 PM   #35 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
I have the same problem with short cycling we share the same component at fault and it's in the design of the Furnace.the part # is 90 - 15 F. translation 90° on reduce 15° off and F you get that one. Yes the fire is cooling off the Firebox by 15 degrees telling the system that it is safe to turn off the fan because the fire is been extinguished an adequate period of time to reduce the heat soak and chances of thermal cycling causing cracking from uneven Cooling. My furnace is a Coleman. I first discovered the problem when I Eco modded the furnace upon my arrival at the new house. I added a duct to the face that made it pull cold air from the floor instead of the hot air off the top where the air filter is. This changed the Dynamics of how the machine was operating and would cause the heater to short cycle adding a restriction to slow down the air flow rate put a bandaid on the problem. This was more efficient in that they furnace was able to maintain air flow over the heat exchanger from flame On to flame Off instead of having the fire on continuous and stopping the fan every 3 minutes for 5 minutes( this made it hard for me to sleep as the furnace is on the other side of the wall from my bed and Mobley homes they are no good for slowing down sound much less deadening any) I call it a Band-Aid because adding a restriction in front of the blower motor causes the motor to consume more watts producing heat energy he just heat so this is not the loss but the reduced service life will take a toll eventually it's already 30 years old.
Regardless of the ducting or not too cold of air cools the fire off too fast setting 55°f is too far outside the normal design parameters. I want to set it for 40° when I'm not home only enough to keep the pipes from freezing. The other type of problem I had was the bi-metal spring thermostat headstone spring amathing one too many times. And I wanted a digital programmable thermostat. So I bought a Honeywell 5 + 2 $20. This worked great so long as you didn't mind the Blasted thing coming on every 15 minutes massive downgrade from the broken by-metal. I determine the problem was the window of operation is too small on one degree below set off one degree above set basically by the time the air settles out from having been warmed and cold things suck heat out of it it's time for it to come back on. So I called Honeywell the manufacturer, who basically told me suck an egg this is what we build we're not going to give you enough specifications on the internal workings of our product for you to reverse-engineer /adjust the hysteresis setting. But I got a good technician one who was patient and could follow those path I lead. The thermostat has two settings on the backside little dip switch position A electric or gas furnace position B hydronic/ boiler. I was able to get the information from the tech that yes indeed electric and furnace are set + -1 degree. And hydronic is set + -3 so now I run my gas furnace in hydronic mode giving me a slightly wider window of soak time and a light duty automatic pulse and glide.
When I bought the house I also bought a pellet stove used from Craigslist $500. On low it will activate the blower motor on the furnace when it gets above zero outside for too many hours in the day with the stove set too low. So above 0 I start the stove in the evening and let it run through the night and turn it off in the morning ~65-85°f . Max 1/3 bag(40lbs bag. ) per day with a high above 0°f. I had 28of 50 bags (1 ton)at the start of the next heating season .
I was out of town this spring when we got a hot spell in Montana whopping 80° with the insulation value in the house I got and heat produced from three pilot lights and one refrigerator this caused the inside temperature to exceed 90 degrees and stay there for days on end,$150 bill ouch. The inside never droped below75° so it just sat there circulating the hot air with no call for heat.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 12-18-2017, 03:52 PM   #36 (permalink)
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
I got the adjustable thermo switch in and installed and adjusted to 90*F. Now to wait for it to get cold enough to kick on at 40*F.
Old 12-18-2017, 04:02 PM   #37 (permalink)
I have a coal furnace that I am probably going to put an adjustable thermostat and count down timer on.
You can fix short cycling with a time off delay. I use them on my air compressors so they unload before turning off to reduce the power surge they create.
The time off delays are available in just about any voltage and can range in delay from fraction of a second to hours.
Isaac Zackary (12-18-2017)
Old 12-19-2017, 10:59 AM   #38 (permalink)
Full sized hybrid.
So with the new adjustable thermoswitch set at 70*-90*F and the thermostat set at 40*F I noticed it coming on a lot sooner than with the other thermoswitch after the flame starts. And although there was a couple times that it did shut off and restart it doesn't stay off nearly as long nor does it cycle nearly as much as it did before. So I'm calling this a success for now.
Maybe some day I'll get an Arduino and a bunch of thermistors and dial in the most efficient blower on/off switch in the history of the mobile home. But then again, maybe not.
Old 01-13-2018, 11:56 PM   #39 (permalink)
Full sized hybrid.
Results just in!
From 11-07-2017 to 12-06-2017 the average outside temperature was 33*F and I used 71CCF.
From 12-07-2017 to 01-05-2017 the average outside temperature was 22*F and I used 61CCF!
That's 11 degrees colder and yet I managed to use 10 CCF less natural gas!
The Following User Says Thank You to Isaac Zackary For This Useful Post:
freebeard (01-14-2018)
furnace
