Old 11-06-2014, 05:34 PM   #1 (permalink)
Zip ties and wheel covers
I had one zip tie break in the few hundred miles that I had my wheel covers. Have any of you that attach smooth wheel covers with zip ties had difficulties?
Thanks!
Old 11-06-2014, 06:57 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
There is a guy on here how created a better method. I'll look for his thread
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 11-06-2014, 06:58 PM   #3 (permalink)
mcrews's Avatar
http://ecomodder.com/forum/showthrea...etc-30058.html
ECO MODS PERFORMED:
First: ScangaugeII
Old 11-06-2014, 09:35 PM   #4 (permalink)
http://ecomodder.com/forum/showthrea...aps-30157.html
I have been using them. I am just asking how long zip ties last when attaching smooth wheel covers.
Old 11-06-2014, 10:03 PM   #5 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
zip ties
Mine have lasted a few thousand miles and no breaks.
One thing I did was to make the gap over the coroplast a bit wider than through the rims, so the tie wouldn't bend sharply on the rim, and maybe that helped. For example the gap on the rims is about 1 inch, and I made the gap on the coroplast 2", though probably 1.5" would be wide enough and use less length of the ties, making them easier to put on.
The Following User Says Thank You to j12piprius For This Useful Post:
Xist (11-06-2014)
Old 11-07-2014, 02:44 AM   #6 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
During testing I have also lost one plug in wheelcover assembly. It came off from a cover where the holes werent drilled so straigth compared to the zipties incoming direction. I will shoot a hubcap assebly video today to show how to do it.
I have tested my hubcap assebly to 160 km/h 100MPH speeds with 4 plugs used in the assembly.
If the holes arent in rigth place and specially it the hubcaps dont center themself to the wheel. You need to be extra careful in the assembly:
- Tighthen the plugs litlle by little. To get the hubcap fixed to center of the wheel
- Make sure the locking teeth is facing against the zipties body. This way you know that there is some tension in the ziptie. If it is not touching the tail your connection is not secured properly
- One plug can handle 10 kg of pulling force so they dont break in the assebly phase specially in hubcap assembly.
Some pictures to clear that description:
"Loose"
"enough tension"
Same in video format:
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
MetroMPG (11-07-2014)
Old 11-08-2014, 08:07 PM   #7 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
I had one break about a month ago but it was a thinner one I got from a different batch. Sadly, I lost my upper grill block to the car wash gauntlet. It was acetate so it was doomed from the start. I'm cutting a new upper and lower block this very moment.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 11-10-2014, 04:24 PM   #8 (permalink)
Tinkerer
kafer65's Avatar
Team Mazda
To be clear, the one that I had that broke wasn't the ones that Vekke has. Mine are just regular zipties. I'd like to order some of the ones above at some point though. The one that failed broke at the point where it enters the lock. That one may have been too tight. Is there degredation from ultraviolet light with black ones that we need to consider? I have about 4000 miles all of them. Some of them may have couple thou more.
