Old 09-20-2014, 11:40 PM   #11 (permalink)
Just cruisin’ along
jcp123's Avatar
Beater Echo - '00 Toyota Echo
90 day: 42.67 mpg (US)
Hondizzle - '97 Honda Civic DX
90 day: 46.55 mpg (US)
Shaggin Waggin - '14 Chrysler Town + Country
90 day: 22.56 mpg (US)
Take em off. Run beauty rings and chrome acorn wheel nuts. Classic look. Better than seeing steelies behind that hub cap, IMHO. I say this because I inherited this car without any wheel covers, and because I've always like the steel wheel/trim ring look. Base model badass.
As for aerodynamics, I'd say leave em on.
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
Old 09-21-2014, 12:28 AM   #12 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
i actually tested this, i was actually tring to compare hubcaps to hubcaps taped smooth, but i figured i'd throw in no hubcaps.
the results, the data is a lil messy but i was not able to show any significant difference between the untaped to taped hubcaps. however, no hubcaps showed about a 1 1/2% loss
http://ecomodder.com/forum/showthrea...ard-28594.html
The Following 3 Users Say Thank You to 2000mc For This Useful Post:
aerohead (09-25-2014), FordFiestaS (09-21-2014), PaleMelanesian (09-22-2014)
Old 09-21-2014, 09:40 AM   #13 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Check it:
http://ecomodder.com/forum/showthrea...yle-29223.html
There are other solutions too that may smooth your wheels without looking too dodgy. There's "poor man's fiberglass," T-shirt material stretched tight and then painted to make it hold its shape (multiple coats may be necessary), which brings the added bonus that you can choose the color. I think you could get similar results using Tyvek.
Redneck pointed out that his plastic smoothies eventually broke down under constant sunlight, you might fare better by choosing some tougher plastic than garbage bags. Maybe lawn-and-garden bags?
The Following User Says Thank You to elhigh For This Useful Post:
Old 09-21-2014, 02:16 PM   #14 (permalink)
I always thought the purpose of a hubcap was to retain the lug nuts if they loosen and fall out...and rattle so you fix the problem. These are worse than useless. They add weight to a steel wheel so it will look like a lighter wheel.
That said, some people won't drive a car that doesn't look bone stock. Go figure.
Old 09-22-2014, 09:55 AM   #15 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
These are certainly more aerodynamic than bare steelies. I'd leave them on, until/if you decide on something even smoother. The added weight is negligible.
Old 09-25-2014, 05:27 PM   #16 (permalink)
caps
I vote keep 'em on,or modify.
fiesta, hubcaps
