Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 03-07-2013, 10:08 AM   #1 (permalink)
Send a message via MSN to markweatherill
Tall tales (ICE running on water)
I was speaking to a gentleman the other week who claimed to be some kind of engineer, he said one of his relatives had worked on the water charger that was fitted to WWII aeroplanes, I said 'Ah! water injection?' He said No, no, running on water... I asked him if it was HHO and expressed scepticism about that, he went on to explain that if you compress water (in a very strong steel tube), and pass an electric current through it, it creates an arc, atomises the water, and you get 'fusion gas'; that is what produces the power. His car outside, he said, had these tubes in each spark plug hole.
The enormous pressures needed to compress the water come from the car's vacuum system. And so on, all with a perfectly straight face.
Just thought I'd share that. I wonder if you did do this, put a body of water under great pressure and pass electricity through it, what would happen?
Old 03-07-2013, 10:43 AM   #2 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
Water will not compress... It just won't.
If you pass electricity through water... electrolysis happens and it will produce gas but the amount of electricity that would be required to power something would be more than the output you would get. Maybe they were using a steam engine of some sort? Maybe using an electric heater to create the steam?
Project Avalon: E bike build
Old 03-07-2013, 12:58 PM   #3 (permalink)
...beats walking...
OP...uh, just tell that 'gentleman' to:
1) lookup the meaning of HYDRAULIC LOCK in conjuction with water.
2) lookup the meaning of ELECTROLYSIS in conjuction with water.
Old 03-07-2013, 03:22 PM   #4 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
A vacuum system doesn't compress stuff.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
Old 03-07-2013, 06:22 PM   #5 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Just for the record
Properties of water - Wikipedia, the free encyclopedia
Old 03-07-2013, 07:19 PM   #6 (permalink)
radioranger
he must have the Chlorophyl device , where you add sun to water and wait ,
The Following User Says Thank You to radioranger For This Useful Post:
Cobb (03-07-2013)
Old 03-07-2013, 07:37 PM   #7 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
I have this bridge I'd like to sell you.
The Following User Says Thank You to t vago For This Useful Post:
radioranger (03-07-2013)
Old 03-07-2013, 07:42 PM   #8 (permalink)
Old fogies in America like to tell tall tails to any who will listen.
I met or this guy met me and started off about energy, then tesla, then free energy, then how he was abducted by aliens, then ufos, then he wrote a book about them, then he had a heart attack, then the book wasnt published, then the government tried to silence him and his story just kept going longer than I had interest in it.
Old 03-07-2013, 07:45 PM   #9 (permalink)
radioranger
those guys get around !! there's a few in my area.
Old 03-07-2013, 07:53 PM   #10 (permalink)
Are those guys fuelled by ethanol?
