Old 03-01-2010, 01:13 AM   #1 (permalink)
sr185 bullet - '81 Yamaha SR185 streamliner
Team Streamliner
90 day: 96.35 mpg (US)
Sunny Colarado - '06 Chevrolet Colarado WT
90 day: 24.18 mpg (US)
cbr250s - '12 Honda cbr250
90 day: 115.29 mpg (US)
snowy Mpgs
Hi,
I've been reading up on hypermiling and modding lately, and am interested in improving my MPGs. the problem is that I am a Yooper, (that means I live in Michigan's Upper Peninsula BTW) and have to deal with large amounts of snow, and rain. we get between 120" and 200" of snow annually. sometimes more. I own a '99 Plymouth Breeze, and I plan on installing a block heater and an MPG gauge, I was wondering if anyone had any good suggestions for cold wet climates.
Old 03-01-2010, 01:46 AM   #2 (permalink)
grille block, engine blanket, brush all the snow off it, keep tires aired up, don't idle "to warm up".
bschloop (03-01-2010)
Old 03-01-2010, 02:19 AM   #3 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
I'll add use good winter tires, as the less spinning of wheels the better. Drive in tracks already made where able, slow down as sliding is usually a waste of energy.
Install in addition to the block heater a circulating coolant heater and a small blowing heater to heat the cabin up before you start up. Run those for a couple hours before you drive. They can all plugged into a three way outlet that way you only plug in one cord, but be sure that the cord and the threeway is rated for a bit over the combined wattage of all your heaters.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
The Following User Says Thank You to bestclimb For This Useful Post:
Old 03-01-2010, 03:07 AM   #4 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
The good news is that snow tires roll better than the average, so you can change them when it is mild. I wouldn't bother with interior pre-heat unless misting is the issue, and you want to get moving right away. Cabin heat is free when the engine is on. FWIW, "Underpowered" cars warm up faster.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
Old 03-01-2010, 07:45 AM   #5 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
a yooper. I'll have to remember this...
I too am in a crap hole for cars.
I gave up on grille block, keep heat rise away from exhaust,
strengthen fire and other old hot rod tricks, and away it goes...and never ever take away outside cold air into the intake..EVER.
the breeze always looked like it had tiny wheels to me, maybe step up the tire size, keep rpms down. the engine is a gigantic fuel injection, I am sure it could handle it.
The Following User Says Thank You to bgd73 For This Useful Post:
Old 03-01-2010, 09:04 AM   #6 (permalink)
Team Streamliner
Thanks to all. You have confirmed many of my suspicions. I'll be installing a block heater, and will go from there
Old 03-01-2010, 01:04 PM   #7 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
I would add that the adhesive backed heating pads work great on your oil pan and transmission pan. Helps my ATX achieve Torque converter lock right away, instead of miles away. My motor doesn't rattle at all on cold starts because the oil is nice and warm.
Engine block heater is a great thing. It make almost a 3-4mpg difference for me on 20 degree days.
Old 03-01-2010, 06:45 PM   #8 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I would also suggest a grill block, I have one on my Matrix and have found that it adds significantly to my warm up times and therefor to my fuel economy. Over the last weekend I got 41.1 MPG.
Where in the UP are you at? I will likely be heading up there within the next 2 weeks.
Old 03-03-2010, 12:16 PM   #9 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Would those stay on if you're scraping the bottom on snow a lot? Not to mention the subzero temps that make most adhesives just fall off? I've never lived in the UP but I'm an hour south of the bridge, and I've visited the UP a lot.
I had thought of using salvaged heating elements and thermostats from dishwashers to put in the oil and trans pans. The elements and end fittings are leakproof. Trans pan would be easy assuming there was room for it. Oil pan might not be worth it if the engine has to be raised from its mounts to remove the pan like on my cars.
Winter daily driver, parked most days right now
Summer daily driver
Old 03-04-2010, 01:10 AM   #10 (permalink)
Honda Ecomodder
redline5th's Avatar
The Civic - '98 Honda Civic DX
90 day: 41.59 mpg (US)
I would definitely add a block heater. If not for economy then for engine longevity!
http://thechriscoleman.com/
Alas.... no more 40mpg -- Now B18C swapped.
improving mpg's with led taillights? GenX Rolla EcoModding Central 38 11-02-2022 11:03 PM
Newb - better MPGs out of a Dodge Neon? stevewww EcoModding Central 7 10-21-2011 08:50 AM
Green Tires From Orange Peels Use Less Oil, Bring Better MPGs Daox General Efficiency Discussion 24 12-16-2009 09:24 PM
MPG's or Drive Less? DifferentPointofView EcoModding Central 13 06-22-2009 12:32 PM
Squeezing MPG's out of a Jeep - or atleast trying. RoboMike EcoModding Central 56 07-01-2008 10:22 PM
