03-14-2010, 09:30 PM
#21 (permalink)
A madman
I actually just got done assembling that identical trailer! Waiting for paperwork to come through so I can get a plate on it. I was surprised it only had a 1 7/8th ball but I guess it doesn't have brakes either, so its fine for less than 1 ton carrying.
I need to get a floor on it soon to start using it!
03-14-2010, 09:35 PM
#22 (permalink)
They told me it has a 2" ball. Now I have to go look...
03-14-2010, 09:40 PM
#23 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
That's why I have a multi-ball w/ a tow hook on it.
03-15-2010, 01:54 AM
#24 (permalink)
It is 2". Brucey must have a different version.
03-15-2010, 01:55 AM
#25 (permalink)
After non-profit and employee discount, I ended up buying the hitch and getting the multi-ball receiver free. I couldn't pass up that deal... tis' nice to have friends.
03-15-2010, 02:16 AM
#26 (permalink)
I considered the multi-ball, and even a super cheap single all welded ball receiver, but for some reason I wanted a bolt on ball I could remove/change out. This car will never have a bigger/smaller/other trailer behind it anyway...I don't think.
03-15-2010, 12:00 PM
#27 (permalink)
A madman
Odd. Was yours from Harbor Freight too or did I miss that?
I'm also having to wait on the Certificate of Origin so I can get a plate, they had to mail it to me because I bought it out of state.
Either way, mine seems pretty sturdy for coming in a kit, I'd trust it with a 1 ton load. The only thing I felt needed improving was the coupler to the front A beam. I could almost pull the bolt heads through the plate, so I added a few washers there.
Maybe yours is improved there too.
03-15-2010, 03:37 PM
#28 (permalink)
You have a lighter model; 1120 lbs capacity IIRC. The frames are identical but I think the axle, hubs, wheels, and tires are different; along with the 2" coupler, mine has 5 lug "55 mph" wheels and tires. I vascillated between the two but went for the heavy one cuz it was only $90 more.
03-15-2010, 03:43 PM
#29 (permalink)
To upgrade after purchase will cost more than $90, though, of course.
Smart decision to go w/ the heavier duty version, Frank. While it's usually a good idea to use the least you can to get the job done, I feel like the difference here could have been considered negligible, at best.
I've got a Toyota Tacoma that I'm about to cut in half and turn into a trailer, myself. I can swap the truck title for a trailer title with not too much trouble in PA, from what I hear.
03-15-2010, 03:56 PM
#30 (permalink)
Exactly. For a while I thought, get the lighter one then upgrade the tires later. But a pair of wheels n tires alone was more than $90, then the hubs and perhaps axles and springs are still lighter. The heavier wheels don't bolt up anyway. I envisioned bent/broken axles in the middle of Nebraska at 3 a.m. and then decided to go heavy. Perhaps there is a car 5 bolt pattern that fits and someday I'll put car 13s on it.
