Old 05-08-2015, 01:56 AM   #11 (permalink)
90 day: 30.54 mpg (US)
The kit and werkzeughalter arrived later today, so I will tap the hole and try to put Bacon back together again tomorrow, although I also want to go to Mom's for Mother's Day.
I messaged the friend, asking if we could talk. A day or two later, she asked about what.
Really?
I called after "work" today and she acted like everything was normal, so I asked if we were okay, and she started going off about how rude I was. I pointed out that she knew that I was at the house of another woman.
"Yes, but you did not tell me that she was there with you!"
"I said [Name], I need to go, [Name] just came home."
"I didn't call to tell you about the milkshake machine!"
No, she called to take me away from another woman...
I pointed out that she also knew how important it was that I fixed my car. She responded that if I did not have time to talk to her, I should have told her that I needed to go.
So, I told her that I needed to go, and hung up.
She did not seem to appreciate that.
Old 05-08-2015, 11:01 PM   #12 (permalink)
Well, the werkzeughalter was a kinderwerkzeughalter, which I exchanged for their smallest tap and die set. I do not have any idea if that was big enough, I used the Go 2 Socket, and then the handle from the set. I was not able to use the guide that I bought, the process required two hands, and it did not fit the oddly-sized bit that I needed. It did seem to self-guide, though. I did not purchase the tapping oil, I just used motor oil. hopefully that works well enough. It took a while to get the bit started and the helicoil wanted to go in crooked, but I definitely felt that the most difficult part was figuring out which tools I needed!
Old 05-15-2015, 09:18 PM   #13 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
I've never had to use a helicoil.
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
