Old 10-19-2014, 10:58 AM   #1 (permalink)
EOCing problems
I have an '09 Sonata, 4 cyl, 5 spd. I have EOCed it using the ignition switch on a regular basis since new. It now has 110K on the clock. Last week, I did a typical EOC on a downhill stretch on the interstate. After popping it into 5th, I got a flashing CE light and it seemed to be running on 3 cylinders.
I pulled off at the next exit. Shut it off, restarted. No CE, running like new.
WTF?
I have not EOCed it since.
Any ideas?
A few weeks ago I did get a solid CE light after an EOC while on cruise control. It ran fine during this stretch for a few miles. When I disengaged the cruise and lifted the throttle, the CE light cleared.
Would installing a FI cutoff switch possibly avoid these problems? I really should as 09 Sonata headlights go off with the ignition switch, making ignition switch EOCing at night kind of interesting.
Old 10-19-2014, 11:32 AM   #2 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Do you have any way of checking for codes? That may give you anindication of what happened.
Sounds like a good choice until you get it figured out.
Old 10-19-2014, 11:55 AM   #3 (permalink)
It's been many hundreds of miles since. Would the codes still be stored?
Old 10-19-2014, 12:02 PM   #4 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
Same thing happens in my KIA I just kill it again and bumpstart again and it goes away. I got a code for the fuel injectors. It probably thinks something is wrong because the engine keeps cutting out.
Old 10-19-2014, 12:12 PM   #5 (permalink)
nemo's Avatar
Some codes are retained even if the light goes off.
Old 10-19-2014, 07:32 PM   #6 (permalink)
dirtydave's Avatar
Duct Tape Aero Crew
Team Chevy
And you need a kill switch it will change your life lol.
