Old 09-29-2009, 04:52 AM   #1 (permalink)
Whitey - '05 toyota corolla LE
90 day: 28.91 mpg (US)
Send a message via AIM to blackjackel Send a message via MSN to blackjackel Send a message via Yahoo to blackjackel
Non permanent glue? Something that actually holds?
I need to glue a CB radio mount to my car cause i want to be able to remove it if I resell the car.
Hot glue did not work, soon as it got too hot the mount fell off with the CB radio.
So does anyone know of any non permanent glue that will actually hold?
Old 09-29-2009, 05:03 AM   #2 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
construction adhesive. {liquid nails} The stuff they use to glue kitchen counters on with or mirrors to walls...
Three big globs should do the trick, and peal off fairly well when you're done.
Old 09-29-2009, 06:13 AM   #3 (permalink)
cool, but then how do you try to take it off? Do you have to chisel at it or what?
I'm wondering how can something hold strong and not be permanent. For the hot glue i planned to blast it with a hairdryer to take it off, i didnt think it would get so hot in the car the glue would just peel off!
How do you get liquid nails off?
Old 09-29-2009, 09:33 AM   #4 (permalink)
construction adhesive (liquid nails) dries a little softer than your hot glue and should stick well to a cars plastic interior. Your hot glue dries out too much to hold the weight and fails from the vibrations. Being softer and stickier liquid nails should hold for a few years if applied correctly. Liquid nails should also snap off with some gentle prying and clean up with thinner.
Old 09-29-2009, 11:37 AM   #5 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Use silicon caulk, you will have to use a razer blade to get it off but it will come off clean and it will not take the paint off.
Old 09-29-2009, 12:07 PM   #6 (permalink)
chuckm's Avatar
Exploder - '02 Ford Explorer xlt
Rolla - '02 Toyota Corolla ce
90 day: 44.43 mpg (US)
Try this stuff. Good adhesion and works up to 180deg F. Can later be peeled away.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 09-29-2009, 12:10 PM   #7 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
I used to have a CB in the old 6000 wagon. I stuffed it between the driver seat and the center console, no bracket.
You may also be able to make a bracket that attaches to existing screw holes.
I'm not knocking the adhesives listed, I bet they are pretty good. Just giving other ideas. Just one thing, make sure to ventilate the car well if you use adhesives. Some adhesives (like seam sealer that looks a lot like liquid nails) gives off strong vapors for days on end.
Winter daily driver, parked most days right now
Summer daily driver
Old 09-29-2009, 12:38 PM   #8 (permalink)
Eco Dreamer
Versa - '08 Nissan Versa SL Hatchback
100% silicon adhesive.
Put it on thick, and when the time comes to peel it off, it will peel off in 1 piece.
Old 09-29-2009, 04:23 PM   #9 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
Could always try THIS
It's what I use to hold the front lip onto my VX.
Old 09-29-2009, 05:07 PM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
blackjackel -
I tried the liquid nails and didn't like it. I was attaching black velcro to the gray plastic edge of solar panels that get 100% sun exposure and it just came off after a while. If I were you, I'd take apart the center console and see if I can find a point where I can mount a bracket, just like wagonman76 says. If you have to drill holes somewhere, find a "not in your face" location and make sure to drill holes in sizes that can be covered up with plastic plugs.
Do you have pictures of the CB radio mount?
CarloSW2
American Solar Energy Society
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Project: making a permanent Metro Kammback extension MetroMPG Aerodynamics 256 09-11-2013 04:22 PM
Permanent Grill Block Raysp30 Aerodynamics 7 10-04-2011 12:30 AM
magnets use for permanent mods ? groar EcoModding Central 5 09-08-2008 03:52 PM
Corplast glue? Otto Aerodynamics 16 09-04-2008 04:04 PM
