09-27-2018, 03:55 PM
5-minute DIY: cockpit-adjustable variable grille block (1-way)
Step 1...
Coroplast blocking plate over existing custom-sized grille opening. Note actuator linkage leading to cockpit.
Step 2...
Monitor coolant temperature while under way. At desired temperature, manipulate actuator.
Step 3...
Step 4 ...
(simulation)
Step 5...
Et voila!
Notes:
1) Best suited to convertible or sunroof-equipped vehicles.
2) The first time I pulled the rip cord, I was going about 50 km/h (30 mph).  Too fast! It flew over the cockpit and almost snapped the actuator linkage! Next time I tried around 15 km/h. Still too fast!
3) You don't want to be too concerned about the finish on the aft end of your vehicle -- the grille block will bounce & flap around back there before you get it reeled in.
Despite the silliness, it works. Speeds warm-up time, and improves aero. It was used on the last part of my recent record tank:
53 MPG tank in 1990 Mazda Miata: personal best (4.5 L/100 km)
The Following 7 Users Say Thank You to MetroMPG For This Useful Post:
09-27-2018, 08:38 PM
Hook the actuator linkage to the wipers for total, semi-automatic regulation.
09-27-2018, 10:48 PM
Hook it to the what?
Those are only on if it's going to rain. :P
09-28-2018, 10:52 AM
ScanGauge <3
That's cool. Good reminder that a complicated two-way system as envisioned by a lot of tinkerers isn't really necessary. I should do something like this in my Outback.
Best tank (so far): 32 MPG
09-28-2018, 11:41 AM
You got me thinking now
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
09-28-2018, 12:35 PM
You could fine-tune/complicate this idea with a series of smaller blocks and linkages!
I used it again today. This fuel hog needs all the help it can get!
09-28-2018, 01:40 PM
Redneck factor is a tad too high
Why not make the coroplast a bit bigger, cut a narrow vertical slot in it on either side, and use properly positioned big headed screws to keep the coroplast on the bumper .
09-28-2018, 01:46 PM
But then it's a 20-minute DIY!
TOO MUCH!
09-28-2018, 03:48 PM
#9 (permalink)
マット
Why don't you put a stud in the air dam then hook light spring to it and the flap, then you can pull the string and tie it off on a cleat?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
09-28-2018, 08:35 PM
#10 (permalink)
What a great idea...
