06-26-2019, 05:25 PM
#181 (permalink)
Originally Posted by Vman455
I guess these guys didn't get your memo:
just because you can put a 2" hitch on your prius does not make it legal to tow 12,000 pounds
2016 Prius has a maximum towing capacity of 1,598 pounds that is a empty car and just a driver
CVTs are the weakest link in towing... you can ask people who blew up there transmission backing up a load in a tahoe hybrid... (reverse gear is powered by the CVT)..
06-26-2019, 08:28 PM
#182 (permalink)
Tyrant-at-large
Who said anything about towing 12,000 pounds? You keep moving the goalposts, and most cars (and trucks, and SUVs) can't tow 12,000 pounds.
That 1,600 pounds is the maximum recommended by Toyota; there's no law in any state that says an owner can't put more than that behind a Prius and have at it.
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
06-26-2019, 09:37 PM
#183 (permalink)
home of the odd vehicles
The Following 2 Users Say Thank You to rmay635703 For This Useful Post:
06-27-2019, 12:32 PM
#184 (permalink)
Redneck Ecomodder
Yes, he keeps acting as if I'm wanting to move my entire setup with only the Prius' motor, I know that won't work.
I'm simply looking for the Prius motor(s?) to add an extra 20 or so ft-lbs to make taking off from still, and maintaining speed up hills a little easier. I know that asking 20 ft lbs from those motors will barely strain them at all; I'm sure I could ask for 100 ft lbs from them and they would still be fine.
05-10-2020, 06:10 PM
#185 (permalink)
Nissan did it
nissan engine with prius hybrid lol
05-10-2020, 06:15 PM
#186 (permalink)
that is all they can get it rated for don't expect it to last very long towing often..
05-10-2020, 08:52 PM
#187 (permalink)
Iveco - '00 Iveco Daily 35s13v
VW XL1!
However i wonder if the Prius drivetrain would be an upgrade or a downgrade?
05-11-2020, 01:26 PM
#188 (permalink)
Originally Posted by iveco
VW XL1!
Most likely a downgrade. OTOH something similar to the HSD scaled-down enough to integrate with its stock engine (or with something else that could seem like an improvement) would be interesting to say the least.
06-17-2020, 02:37 PM
#189 (permalink)
I currently have accumulated over 100k miles on my Prius WHILE TOWING A SMALL CAMPER! My Prius has 155k miles total. It doesn't burn a drop of oil and still has the original transmission, brake pads hybrid battery etc. it has crossed the usa multiple times, been all over the rockies and up some pretty scary gravel roads......again...while towing a small camper. So far it has towed in 46 states and 10 Canadian provinces.
The Following 2 Users Say Thank You to Yippeekyaa For This Useful Post:
06-24-2020, 07:43 PM
#190 (permalink)
Makes me wonder how the previous generations would withstand to such use, since their power-split device had a chain while yours doesn't resort to it.
