Old 04-04-2019, 11:03 PM   #1 (permalink)
Round Trip With A Prius And Trailer
Given a trailer that neither increases, nor decreases CDA, will the return trip down hill make up for the first trip uphill with a 500 lb trailer?
Old 04-04-2019, 11:16 PM   #2 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
In theory yes, but in practice, no. Reason being is the weight will require more energy to move uphill, and returns more energy going downhill. If the down grade is steep enough you’ll finding yourself using the friction brakes, turning all that “free” energy into heat and brake dust... best pot case is a grade gentle enough to allow you to DFCO down the other side and have the engine hold you back using no fuel... you’re still gonna have to brake at some point though...
My current Ecotec project...
My last Ecotec project...
Old 04-04-2019, 11:23 PM   #3 (permalink)
The cruise control on the Prius reverses the electric motors to slow the car and puts voltage back in the battery. I know I can't legally harvest that kinetic energy through gathering speed on the down hills, and I know there will be some loss of efficiency translating kinetic into electric. I was hoping for some experience from someone who had monitored their mileage both ways
Old 04-04-2019, 11:39 PM   #4 (permalink)
Team Saturn
Yes the Prius uses regenerative braking, but at some point the battery will be full and you’ll have to use the friction brakes to slow down... if you had a long runoff at the bottom of the hill you could harvest the energy as kinetic energy (at risk of getting nailed for speeding) and then coast down over a long distance...
Old 04-05-2019, 03:15 AM   #5 (permalink)
90 day: 29.78 mpg (US)
If it's a standard Prius, the battery holds very little energy.
I've filled my 3.2 kWh Prius plug-in from empty to full coming down from Yosemite, and that was without a trailer.
MetroMPG (05-16-2019)
Old 04-09-2019, 07:58 PM   #6 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Unless it's a boat tail trailer, it will increase Cd and therefore CdA.
I've seen record trips with a small garden trailer, but that's towing with a 2ton van where the trailer is hidden entirely in the TV's wake.
Old 04-09-2019, 08:53 PM   #7 (permalink)
Mine will be hidden entirely in the Prius wake. It will be 4 feet wide and 40 inches tall.
Old 04-10-2019, 12:08 AM   #8 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
In theory no, unless you hold constant velocity up and down the hill (i.e. acceleration = 0) and assume no increase in rolling resistance due to the trailer, which wouldn't be accurate. Even with the added mass of the trailer, the extra help you get from gravity is not enough to overcome the additional work required to move it in the first place. If you draw the FBD and do some algebra--
M = mass of car
m = mass of trailer
T = angle of hill (assuming same angle up and down)
d = distance of hill, and assuming duphill = ddownhill
FD = aerodynamic drag force, assumed same for both
FR,car < FR,car+trailer = force of rolling resistance
You end up with the following work required for each situation to go up and down a hill of distance d at inclination T:
Wcar = 2d(2Ma + 2FD + 2FR,car)
Wcar+trailer = 2d(2Ma + 2ma +2FD + 2FR,car+trailer)
The gravitational force does indeed cancel out, but it cancels out in both situations and you still have the force required to move the trailer around, whether uphill or downhill, which doesn't cancel. So, even if a = 0 it requires more work to get the car and trailer up and down the hill than the car alone, and thus more fuel.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Old 04-10-2019, 02:01 AM   #9 (permalink)
We are planning a round trip in July from Texas to Wisconsin, and back. I'll let you know the going, coming, and overall when we get back.
Previous trips with no trailer, but all our gear in the back of the car gave us 40 MPG. If I design the trailer skin correctly, I'm hoping to reduce drag on the rear of the car.
Old 04-12-2019, 10:21 AM   #10 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Rolling resistance still increases either way. At max, aero drag is still only 80% of total drag on the car at 70 mph, and only goes down as speeds decrease.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
