Old 12-29-2023, 11:54 AM   #1 (permalink)
Illuminati Motor Works 200-mpg-e EV
This is a Aging Wheels, YouTube video: Seven is a Hyper-Efficient Home Built EV Built for the X-Prize', from November 5, 2023.
In this video, the owner associates Cd 0.22 with the car, compared to Cd 0.165, back in 2012 when it competed in the X-Prize, 4-passenger class.
At 200-mpg-e, and 6-miles per kWh, the Seven is in Mercedes-Benz Vision EQXX range territory.https://www.google.com/search?q=YouT...qE2a7PHpE,st:0
COcyclist (01-04-2024), Joggernot (01-01-2024)
Old 01-04-2024, 11:06 AM   #2 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Cool video. It is a good example of using aerodynamic principles to get low drag.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
aerohead (01-06-2024)
Old 01-06-2024, 11:32 AM   #3 (permalink)
'example '
Yes, and it has enough 'camera' angles that, I was able to pull some measurements from screen-shots, in order to do some rough dimensional analysis of the car for the first time since 2012.
