Old 03-25-2012, 11:08 PM   #1 (permalink)
mikehallbackhoe
honda crx - '84 honda crx 1300
90 day: 55.83 mpg (US)
drilling disc brakes
I was wondering if there would be any benefit to drilling holes in my 84 crx disc brakes. I know it helps them to run cooler, and improve wet braking, but what about weight reduction ?
Old 03-26-2012, 12:05 AM   #2 (permalink)
The 'Vic - '96 Honda Civic DX
90 day: 39.3 mpg (US)
No, there are almost no real benefits to drilling your disc brakes. You will shorten the life of the pads and rotors severely. If driving so properly, you shouldn't ever put them under severe duty and then on a CRX you couldn't place them under this kind of load unless racing with a LOT more power. Don't waste your time or effort on this.
Civic Build Thread
Your grammar is appreciated.
3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires
Old 03-26-2012, 12:07 AM   #3 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
No, there are a million easier ways to save 1/16 lb.
Not to mention the safety issues of drilling stock brakes.
Old 03-26-2012, 01:01 AM   #4 (permalink)
ZX - '97 Citroen ZX Monaco
OldContinents
90 day: 61.05 mpg (US)
Carbon brakes might be good for weight saving, but the price will certainly zero any savings from there, also they might not work so well on road usage as from my memory those needed warming up to start working well.
Old 03-26-2012, 01:17 AM   #5 (permalink)
Bad idea.
Old 03-26-2012, 02:23 AM   #6 (permalink)
mikehallbackhoe
I have read about doing it to some disc brakes. one of my concerns is coasting for 10 miles down twisty mountain roads. I tend to ride the brakes quite a bit, and am worried about excessive heat. the crx is pretty light. but the brakes are fairly light duty too.
Old 03-26-2012, 02:38 AM   #7 (permalink)
From what I've heard (not much), slotted is far more effective than drilled, drilled brakes often develop stress fractures and stuff too. Slotted however will reduce pad life by a lot as well.
If you don't feel brake fade, then it's not a problem...?
Old 03-26-2012, 02:55 AM   #8 (permalink)
You run a very real risk of literally blowing up your rotors if they ever do get warm. I mean loud bang sound and then no more rotor for your pads to grab. Catastrophic brake failure in the most extreme imaginable sense.
so no.
2001 Prius - 170,000 KM - just got it (no consistent FE numbers yet)
Old 03-26-2012, 04:09 AM   #9 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Drilling wont help a lot to that fading consern. Use the same calibers and install better brake pads read street brake pads. They wont fade so easily and have better grip.
Yellowstuff 4000 series Product Information Page Index
I have drilled the discs from one of my previous cars. They will start to crack from hole to hole. Specially when you have run them hot in a track and then you drive into water pool etc. First they get twisted and after that they start to crack... So dont drill.
Your mountain driving is propably not nothing compared to racing what they can take also few laps with stock brakes. CRX is so light that it should not have any problems on normal roads of any kind. People race those cars with stock discs and race pads in 24 hour races in Finland .
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 03-26-2012, 04:24 AM   #10 (permalink)
Sven7's Avatar
OP, have you had problems with overheating in the past? I have to push my Rabbit pretty hard (autocross conditions) for a pretty long time to start feeling fade so there probably won't be a problem with you coasting down a mountain.
How about vented rotors and practice some engine braking?
