Old 03-27-2012, 07:58 PM   #31 (permalink)
mikehallbackhoe
honda crx - '84 honda crx 1300
90 day: 55.83 mpg (US)
okay,so I definitely have dfco,so if I am going down a steep mountain road, I should just leave it in gear, with the engine running, no throttle, and it will use no fuel going down the mountain?
Old 03-27-2012, 08:36 PM   #32 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
Correct.
One way to know if it is working is that a carburetored (sp?) engine without DFCO will cackle like mini backfires as the unspent fuel burns off in the hot manifold. My dad's old '71 Ford truck made all sorts of racket going downhill when he engine braked, and so did my old 80 Datsun 210. Kinda makes me remember the old days.....
But anyway, if your vaccuum lines are intact, sounds like you should trust the engine to do its job.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 03-27-2012, 08:36 PM   #33 (permalink)
ZX - '97 Citroen ZX Monaco
OldContinents
90 day: 61.05 mpg (US)
That is how it should be, but do a test, drive one or two tanks with leaving it on gear and see if there is change to your typical method, that should be best way to tell if it is working in your car.
I play only with older cars and there are things people do to them while imagining it will increase performance
Old 03-27-2012, 08:56 PM   #34 (permalink)
mikehallbackhoe
do I have to keep it over a certain rpm, or can I just put it in 5th, and let the rpms drop?
Old 03-28-2012, 12:35 AM   #35 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I think the engine has to be over 1,000 RPM, it varied a little depending on what engine and transmission the car has, but if you are crawling up to a stop light in gear with your foot off the gas you will feel the engine kick back in when it reaches that minimum RPM, it's set just enough above idle that the engine has time to fire up instead of stalling if you press in the clutch.
It's a great design and it allows you to stop burning gas for short bits of time that otherwise wouldn't be worth turning the engine off for.
Old 03-28-2012, 01:08 AM   #36 (permalink)
mikehallbackhoe
thanks for all the info. I started with a brake question, but gained a lot of info. the more I learn about this little crx, the more I like it.
