Old 05-17-2013, 08:04 PM   #1 (permalink)
IamIan's Avatar
Impact of Ethanol % of Efficiency Tests
Link
As the Title says.
Interesting find:
VEE is on average 2.7% higher for ethanol/gasoline blends than for gasoline but varies within a wide range from 14.9% lower to 23.6% higher.
-14.9% Energy Efficiency to +23.6% Energy Efficiency ... is a drastic swing, in the YMMV concept.
Old 05-17-2013, 10:57 PM   #2 (permalink)
Yep it varies depending on each car, my Stratus follows the energy curve almost perfect, the Impala does better with E85 than it should. Comes down to $/mile to me so E85 has to be 20% cheaper for the Impala or Suburban before it for me to use it or for me to play with blending again.
http://ecomodder.com/forum/showthrea...l-18896-3.html
Link to my limited testing
Old 05-19-2013, 03:53 PM   #3 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
This seems to be another study trying to change how we look at things. This isn't the first time I've heard efficiency of energy used instead of efficiency of volume. Obviously a fuel with a larger energy density is desirable for consumers but doesn't necessarily mean it is a better fuel overall. Diesel is nice because it is high density fuel used in a more efficient engine. But Ethanol seems to be the lesser of the three because of energy density but is actually capable of Diesel levels of efficiency with Gasoline levels of power. I'd like to see some more studies like this. Particularly while the EPA is mulling a idea for E30 as an alternative to Premium Gasoline.
-Allch Chcar
Old 05-19-2013, 06:20 PM   #4 (permalink)
...beats walking...
...*IF* EPA mandates E30, then EPA should perform ALL their milage *tests* on E30 and NOT the Indolene G100 that they currently use!
...yes, EPA can *measure* pollutants on Indolene, but their milage tests should 100% represent the reality of what's actually used!
Old 05-19-2013, 07:03 PM   #5 (permalink)
EtOH
They are not going to mandate E30 nor do they mandate E15. The idea is to allow manufactures to certify their cars on it. A much better idea than just declaring all cars 2001+ legal to operate on a fuel when the manufacturers are saying they won't warranty it. If they certify it would be no different than cars certified as Flexfuel vehicles. Except they are designed to run on E30 instead of haphazardly tuned to compensate.
-Allch Chcar
The Following User Says Thank You to Allch Chcar For This Useful Post:
Frank Lee (05-19-2013)
