View Poll Results: Would you use a flammable refrigerant?
I'd consider it 18 81.82%
No way! 4 18.18%
Voters: 22. You may not vote on this poll
Old 07-03-2019, 05:38 AM   #81 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I should start collecting water from AC condensate.
Old 07-03-2019, 05:51 AM   #82 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
. but spraying water on it works also I used to do that on my old car before i drove it so the A/C would "work"
it was a beater so it did not matter using tap water
Old 07-03-2019, 06:12 AM   #83 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I am pretty sure impurities in water causes an effect called boiling point elevation. Distilled water will boil at exactly 100 deg C (at sea level). With impurities the boiling poit is elevated.
Old 07-03-2019, 06:20 AM   #84 (permalink)
distilled water DOES not boil
evaporate yes
BOIL no
Old 07-03-2019, 09:39 AM   #85 (permalink)
teoman's Avatar
A3 - '12 Audi A3
That is a special case, when it is superheated.
It does boil under normal circumstances.
Old 07-03-2019, 09:43 AM   #86 (permalink)
I tried it. Maybe I didn't do it the "right" way, but it boiled. I filled a clean Pyrex measuring cup with distilled water and microwaved it and it boiled just fine. I think realistically even if the water itself is completely pure, it will still boil under normal conditions because of contamination anyways. FOr example, there might have been some mineral residue in the cup from when I washed it, or a spec of dust may have fallen in it.
Old 07-12-2019, 05:29 PM   #87 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
https://www.motor1.com/news/301751/s...i-s209-max-hp/
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 07-12-2019, 06:39 PM   #88 (permalink)
teoman's Avatar
A3 - '12 Audi A3
That system is optimized for performance and is very wasteful.
I doubt it utilizes the full vaporization of the water.
Old 03-09-2020, 08:04 PM   #89 (permalink)
I thought of another idea to improve the AC's performance and efficiency: Move the condenser to the roof and stand it up straight so it gets the best possible airflow. I can think of the following advantages of doing this:
1. Better AC performance and longevity. The condenser wouldn't be right against the hot radiator and its airflow wont be blocked by the radiator, trans cooler, bumper cover, and grill. The grill could also be blocked off more without overheating the engine or causing a problem with the AC, which would help offset the aerodynamic penalty a little.
2. Improved engine cooling. The condenser wouldn't be blocking airflow through the radiator or preheating the air flowing into the rad, improving engine cooling.
3. The condenser would be way less susceptible to damage. It couldn't be damaged by road debris or by a front end collision, which is arguably safer too since there's significantly less chance of flammable refrigerant being released into the engine compartment.
4. Less heat soak. The intake air, piping, manifold, and fuel system wouldn't be heated up by hot air coming off the condenser, which is better for performance.
5. Cooler interior. The engine compartment and therefore the firewall and the floor of the car will stay cooler and not heat up the interior as much.
6. The electrical components as well as plastic and rubber parts in the engine compartment would last longer from not being exposed to the heat from the AC condenser, likely the paint on the hood and fenders would last longer too.
The disadvantages would be:
1. Increased frontal area and therefore increased drag, although this could be largely eliminated by mounting the condenser to a folding frame so it can be laid flat against the roof on cool days when the AC isn't needed and during the cool seasons.
2. Some people wouldn't like the way a roof mounted condenser looks, but the heck with their opinion.
3. Increased electrical draw at idle and low speeds. The condenser would need its own fans since it would no longer be able to share the radiator's fans, which would use more power. However, the extra amp draw is less than what you may initially think because the radiator's fans would only need to cycle to keep the engine cool, they would not need to run constantly whenever the AC is on to keep the condenser cool like they would if the condenser was in front of the radiator.
4. The stock AC lines obviously wouldn't be long enough, so custom lines would need to be made to connect the condenser to the compressor and filter dryer.
5. Slightly more weight due to condenser mounting hardware, longer refrigerant lines, and increased refrigerant charge.
Old 03-10-2020, 01:28 AM   #90 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I thought about a similar idea. Using the insides of the A pillar all the way to the back. It is hollow space after all.
You would need to add a bit more insulation on the inside and make the outside a bit more reflective.
Reminds me of a guy who was adding NOS to his motorbike an instead of adding a tank, he tapped the aluminium frame and used that.
My yamaha uses the frame as an oil cooler.
