Old 03-12-2009, 05:43 PM   #31 (permalink)
That is very likely because the EGR system was not working properly in the first place. When an engine enables EGR it has to alter ignition timing. If the EGR system is clogged (which is common because it is a dirty system), the ECU will enable EGR, alter timing, and since it isn't working properly you'll loose power. A better bet for you would be to remove the EGR valve and plumbing, clean it out, and reinstall it.
The car had less than 5000 miles on it when this was done and I bought the car new.
Old 03-17-2009, 11:12 AM   #32 (permalink)
I received the EGR cooler the other day and unpacked it this morning. It looks like it will fit my application. The pipe has an ID of about 1" which is huge compared to the stock Paseo EGR setup. This should do nicely.
I'm still searching for an EGR valve. I'm kind of leaning toward a TDI or other diesel setup since it appears they are flowing much more exhaust gas through their engines.
I am confused when I look at the TDI EGR valves though. They appear to have two vacuum actuators on them. Could one of you TDIers help me out?
Here is a shot of the inside.
Old 03-17-2009, 11:54 AM   #33 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
TDI EGR valves aren't cheap.
The assembly is actually two valves, the EGR valve, and the anti shudder valve.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 03-17-2009, 12:12 PM   #34 (permalink)
What is the anti shudder valve there for?
Old 03-17-2009, 12:26 PM   #35 (permalink)
To get a smoother engine shutdown, and it also ensures the engine actually stops when you turn the key off by starving it of air. Even if fueling is cut, if engine oil gets in the combustion chamber, like when a turbo seal fail, you can get a runaway, so you want to make sure the engine stops.
Old 03-27-2009, 07:18 AM   #36 (permalink)
Used EGR Valve ALH - TDIClub Forums
This one went for $40. Maybe you could post your looking for one and get lucky.
Old 03-27-2009, 08:39 AM   #37 (permalink)
Thanks Tas. I'm still looking at alternatives, but it seems like diesel EGR valves can flow more EGR than gas engined valves. I'll continue my hunt.
Old 03-29-2009, 09:12 AM   #38 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
FWIW
Yesterday in http://ecomodder.com/forum/showthrea...html#post94649
Originally Posted by Tygen1 View Post
I think I found one, and a wealth of knowledge from this MIT paper: http://dspace.mit.edu/bitstream/hand...pdf?sequence=1
It's 115 pages, so don't start it unless you got some time It's quite in depth and covers many effciency topics including EGR dilution, NoX reduction, Lean Burn and Hydrogen boosted Lean burn. Quite in depth.
The first chart is the baseline without any EGR function, the second is with 10% EGR dilution and the third is with the Hydrogen boosted Lean Burn.
Old 03-29-2009, 10:18 AM   #39 (permalink)
Thanks for the link TestDrive. It looks like I have some reading to do.
Old 03-29-2009, 03:50 PM   #40 (permalink)
You're welcome. Though having skimmed through it now, the data seem a little tangential to what you're doing.
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 13 02-08-2013 12:06 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Trouble Code PO401 EGR Flow Insufficient Detected Ford Man Off-Topic Tech 4 12-09-2011 12:45 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
