Old 09-26-2012, 10:03 PM   #41 (permalink)
Originally Posted by some_other_dave View Post
As mentioned earlier in this thread, most compressed air (that you can get at a gas station) has a pretty good amount of water in it. You don't want liquid water in the tires, and it will tend to accumulate a little more every time you add regular air.
Most of us don't add air repeatedly enough for it to be a real issue, unless the air supply you use is particularly wet.
Oftentimes when I use service station air, I use a tire gauge or key or whatever I have handy to let a blast of air out of the line first. If I see water I'll blast until it goes away.
Old 09-26-2012, 10:40 PM   #42 (permalink)
Saskwatchian's Avatar
Eric's Explorer - '01 Ford Explorer Sport 4x4
90 day: 19.05 mpg (US)
E's V - '07 Nissan Versa SL
90 day: 33.11 mpg (US)
My Explorer states 32 PSI on the sticker, I pump my tires up to 35 and don't let them get below 30 PSI unless I am off-roading (it's handy having a high output electric pump along )
At 40 PSI the explorer starts to feel bouncy and unsafe on gravel and other rough surfaces as well as wearing faster in the rear and seems to be more susceptible to being punctured by the crushed limestone they put on northern roads.
Sometimes the sticker is there for a reason.
I also blast water out of lines though I am not convinced it makes one iota of difference as I have never had tires last more than 2 years anyway.
