Old 04-03-2012, 10:45 AM   #11 (permalink)
P.S.
We don't even have to measure... think of the extremes: a tire with 500 psi and a 500 lb load isn't going to have a one square inch contact patch and a tire with 1 psi isn't going to have 500 square inches on the ground. However, there isn't even a small "zone" where that air/weight/area notion works.
one psi would be "flat" where the rim holds the weight of the car up.
500 psi would be exploded.
the sidewalls of the tire hold the car up some in addition to the air. and the rubber "squishes" a bit to where more of the rubber is on the ground then you would expect.
but when the tire pressure is lower, the bottom of the tire pooches out giving the tire more square inches. add air, less pooch.
btw, I don't really rate "genius" - from you, "Person much smarter then me" is adequate.
Old 04-04-2012, 06:38 AM   #12 (permalink)
You'd think a genius would get the premise. And use the proper grammar.
Perhaps tailgunner will present evidence to support his position?
Old 04-04-2012, 12:04 PM   #13 (permalink)
PSI is pounds per square inch.
Literally, you can take the weight of the car (in this case 500 pounds in our example), and divide by the PSI (50 in my example), and get the solution that 10 square inches is required to hold the car up.
Because of Newton's "equal and opposite reaction" , if there is 50 psi pushing down, there is 50 psi pushing up.
We have all seen where if you take a tire off the rim, and stand it up on its tread, the tire holds it self up. therefore, the sidewalls DO hold the tire (and the car) up somewhat.
If we stand on the inside bead of the tire, the tire does squish downward somewhat.
If we take a normal car, let the air completely out of the tire, the tire goes flat, and the rim rests on the ground).
Therefore, the sidewalls of the tire DO hold the car somewhat, but not nearly enough to hold the weight of the car up.
Ok. Back to MPG. Thanks to someone else's post, the majority of rolling resistance of a car comes from tire deflection.
Tire deflection is shown by looking at any radial tire, and the bottom is pooched out, the rest of the tire is "straighter".
As the car rolls, the a particular spot on the sidewall "pooches" then straightens. This flexing of the tire sucks up energy and is known as Hysteresis by the geeky types.
Suffice it to say how much energy it takes to flex the tire depends on the weight of the vehicle, the design of the tire, and how MUCH the tire is pooching.
Most of us cannot change the weight of the vehicles signficantly. Radial tires flex easier then bias plies, and new tire technology flexes easier.
one thing EASY to change is how MUCH the tire flexes. We do this by keeping our tires inflated at maximum recommended amounts - this means the tire pooches less, and we get better mileage.
As a side note, when a tire gets low in air pressure, the tire pooches a LOT which builds heat in the tire which is why a tire gets really frigging hot and can actually catch fire if you drive down the freeway on a severely underinflated tire.
Old 04-04-2012, 05:34 PM   #14 (permalink)
Still wrong about the contact patch size thing, tailgunner. The rest of it looked pretty good, although if a guy didn't already know he'd think sidewall flex was the biggest culprit in rolling resistance, but it isn't: the tread flexing is.
Old 04-04-2012, 05:35 PM   #15 (permalink)
Tire Geek
CapriRacer's Avatar
Sorry!
Originally Posted by drmiller100 View Post
PSI is pounds per square inch......
Doc - or is it D R?
Either way, I've truncated your post. No need to repeat.
- And while it is entertaining to watch you 2 ***** slap each other, Perhaps you ought to look at this:
Barry's Tire Tech
The Following User Says Thank You to CapriRacer For This Useful Post:
MosersMopars (04-04-2012)
