Installing MPGino in 2002 Golf TDI
Just received a pre-Assembled MPGuino Donated to me by DCB.
I have to Stress that this project would not be happening now without DCB's kindness. I Do plan on donating to him/ the project as soon as the checking account recovers from http://ecomodder.com/forum/showthrea...time-7971.html. Only thing accomplished so far is soldering the LCD to the unit. More to come hopefully tonight. Any + All information regarding the TDI's VSS + Fuel consumption is highly appreciated. Threads which will contribute to this project. #1) http://ecomodder.com/forum/showthrea...lity-3978.html 2)http://ecomodder.com/forum/showthrea...audi-4912.html 3)MPGuino - $40 FE gauge - TDIClub Forums Very Excited. |
Few Pics to get you guys excited
A Few Pics
The Surprise Package http://gallery.me.com/dremd/100055/I...12418210320001 Well Packed (but bad pic) http://gallery.me.com/dremd/100055/I...12418206190001 Un-Packed http://gallery.me.com/dremd/100055/I...12418206630001 My Poor Solder Job http://gallery.me.com/dremd/100055/I...12418207800001 |
Sweet, glad it survived. Yellow wire ground, black wire next to red, 12 volts. Car battery in driveway. Couldn't test it without the LCD, hope it boots :)
note: do try to be deliberate with the power hookup, occasionally these AVR chips mess themselves on flaky power connections. |
Excuse my ignorance; does the +12 volt need to be switched, or always on? I Seem to remember that SVO had his wrong for a while; but I can't remember which way it goes.
Either way I'll wire it up with the main fuse out, charge all of the caps through a test light, then replace the fuse; or should I just hit it with 12 volts right off the bat? |
The trips reside in ram so you want constant power (not switched). You can just firmly hold the power leads to the battery for an initial test.
As far as my untrained eyes can see; all is well with the unit!
Thank you for that, was not sure. In the setup screen (tap left and right together) on the newer ones (>=.81) there is an "InjTrg 0-Dn 1-Up" option that should be able to invert the signal, you want to use 1 for the audi/vw fuel consumption signal.
I also think yours might uniquely say it has a "Metric" option. It doesn't really, It just escaped in the middle of some testing. |
Quick question; If I only hok up fuel signal; what will happen?
Will gph work? Just trying to test. |
That's correct, you should get an indication in gph. It may not be accurate until you get it calibrated but it should be proportional if you get the injector slope "InjTrg" setting right. Even without the vss/distance it is still very useable information there, especially for a fixed length commute (or for finding the best route).
Looks Like Pin 66 on the 80 pin connector does the N146 (quantity adjustment) trick. It's a Brown and red wire; now off 2 find it. Also working up a How 2 at the moment. |
