Old 09-09-2020, 03:33 PM   #11 (permalink)
cross-sectional area
I'm perplexed by the increase the cross-sectional area compared to the typical pencil shaped body.
Every time I draw a hump over a vehicle cabin that is higher than needed for headroom it gets shot down.
It's the whole 'laminar' trick.
The boundary layer will remain laminar as long as pressure is lower in the flow direction.
Once the first ( only) minimum pressure ( maximum local velocity ) is encountered, after that, in the lee of the maximum cross-section the pressure increases as the cross-section contracts, and the laminar boundary layer 'jumps' to turbulent boundary layer, with terrific, comparative viscous shearing losses.
For us, typically submerged in Earth's own turbulent boundary layer, we can never have a laminar boundary layer, on account of Reynolds number effects. At 41,000-feet it's different.
Old 09-09-2020, 03:41 PM   #12 (permalink)
People just ignore me.
Old 09-11-2020, 01:12 AM   #13 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
The powerplant makes the plane. The diesels have 10~15% better BSFC than a gasoline engine. The turbines don't come close.
I was all in for the zoche radials that never quite happened.
https://en.wikipedia.org/wiki/Zoche_...rs%20per%20row.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 09-11-2020, 03:06 AM   #14 (permalink)
I made the same point in Permalink #3.
I am a fan of the en.wikipedia.org/wiki/Split_cycle_engine. I couldn't remember the name Scuderi but the general article shows there is more history. I still think a boxer four would be the best configuration. Gas/compressed air hybrid.
It appears though, that the up 'n comer is the Achates opposed piston engine. Based on the Junkers_Jumo_205 but with modern materials and fuel injection. The current shipping product is a standby diesel generator.
Fairbanks Morse Engine in the 1990s merged with ALCO to make the FMALCO line. In October 2013, FME signed a joint development and licensing agreement with Achates Power to reduce emissions and fuel consumption of Fairbanks Morse proprietary and dual-fuel opposed-piston engines.[18] The opposed-piston diesel engine once made by Fairbanks-Morse is still (August 2019) manufactured as well as the new Trident OP for electric power generation.
en.wikipedia.org/wiki/Fairbanks-Morse#Modern_descendants
Old 09-11-2020, 10:21 PM   #15 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
https://www.machinedesign.com/archiv...lanes-are-here
The 42mpg airplane has been hyped up for what ?
Over a decade, I think it’s more an issue of willpower, getting a tdi approvedfor the air is likely a pain as well
Old 09-11-2020, 11:15 PM   #16 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
It looks great. If I were in that tax bracket, I'd be in.
Transmission type Efficiency
Old 09-12-2020, 12:19 AM   #17 (permalink)
skyking's Avatar
the 310 would get a solid 11 MPG at 21 squared, but you'd get 13 or so if you feathered one and ran the other at 2300 RPM or so. I never went that route
I would daydream about a pair of those zoche 300 HP diesel radials. The ones that never got out of testing :facepalm:
2003 TDI Beetle
2002 TDI Beetle
Old 06-15-2025, 04:21 PM   #18 (permalink)
It's been a five year dry spell, but they're back:
The air scoops and cruciform tail are gone, replaced with turbofans and a T-tail. The increased weight is compensated with a larger swept and slotted wing.
The narrative emphasizes what I like about the Celera -- the prolated ellipsoid aeroform. None of that 70/30 bias of the Zeppelin era.
Old 06-16-2025, 10:12 AM   #19 (permalink)
Part of the Wing and tail feathers may be laminar, but that's it. Fuse bends too much and has bumps. I suspect their airfoil demo, too particularly at high AOA.
Old 06-16-2025, 02:05 PM   #20 (permalink)
Fus[elag]e bends too much and has bumps.
What bumps? One would think that replacing the massive air-sucking scoops for the diesel[s] with streamlined pods standing off on a pylon would be an improvement.
Also very generous filleting at the wing root.
