Old 03-12-2011, 03:23 PM   #11 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
One of the 1st mod is usually a grill block. What if you block the direct air flow to the ram air ?
Not all ecomodder are driving slowly, some aero mod their car because they already have several hours of highway each day.
This is why this article is interesting as you may choose to move your ram air or to open the grill block at the correct place.
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 03-12-2011, 11:41 PM   #12 (permalink)
Laura the Lancer - '81 Mitsibishi lancer LX
cheers frank, another great read.
my mates a mechanic so i might see if hes got one of those monometer things and we might have some fun next time were on the piss.
Old 03-15-2011, 01:23 AM   #13 (permalink)
Ram Air Calculator
Presuming this calculator is right or even nearly so...
It took input of 95 mph, 1000 in/hg ram pressure, and 70 deg temp to get 35% power increase...
Old 03-15-2011, 02:05 PM   #14 (permalink)
Smooth Operator
Old Yellar - '79 MGB Tourer Drop-Hood Coupé
Sports Cars
90 day: 25.83 mpg (US)
Old Brown Ford - '91 Ford Bronco Custom
MAGNUM - '05 DODGE MAGNUM SXT
a different Dynamic pressure calculator
at 60 MPH /88 FPS yields 0.043 PSI *theoretical* Boost to air box
Dynamic Pressure
my scoop in a high pressure area Air Dam
my experience has been that the cheap alum. hose is *blown * to bits over time
when time and energy permits i hope to fabricate a U Tube Manometer
and try to measure actual pressure differentials at various locations in the induction path.
U-Tube Manometer
while this DIY manometer is for use calculating propane tank pressures i think it would work .
at 120 MPH one would expect less than 5 INO2 pressure .17 PSI differential
my operating speeds are 60-70 MPH Max. expect 1.2 INO2 at 60 MPH.
