Old 07-09-2009, 11:48 AM   #71 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Last update for the night: code editor crashed so I lost my to do list, even though I know I had more to upload. Will try to get it all ship-shape tomorrow. Thanks for the debuggering help!
Old 07-09-2009, 12:15 PM   #72 (permalink)
Originally Posted by SVOboy View Post
Added a hybrid option to the add garage bit. Also, added rankings to the video section.
Also, think I made the ecomods section longer, you can confirm or deny that for me
When I initially added the Prius, there was a hybrid selection. When I went to the garage section it labeled the Prius as electric. When I went to edit it, there was no hybrid selection avaliable.
The ecomods section is still cutting off my text. You need a big text field like EM has so you can format it so its readable.
Old 07-09-2009, 12:49 PM   #73 (permalink)
Also, when you click to rate someone's vehicle, it takes you to...
GreenCarAlbum Add Garage - GreenCarAlbum
I also added two albums to the Paseo, and only one is showing as being linked to the Paseo when you look at the Paseo garage entry.
There also seems to be a problem with using apostrophes. It keeps putting /' in instead of just '.
Old 07-09-2009, 02:05 PM   #74 (permalink)
McTimson's Avatar
Maverick - '22 Ford Maverick XLT
90 day: 36.35 mpg (US)
Adding pictures to a new album works - but when I try adding one to a pre-existing album, it just returns 'error'.
Old 07-09-2009, 10:09 PM   #75 (permalink)
Dartmouth 2010
SVOboy's Avatar
Yes, I will code and add the edit garage hybrid feature when you are all asleep in your American bed, I forgot about that part.
Also, I will try to emulate EM, gimme a bit to figure out how to best format it.
I have fixed the weird rating redirect, and added a number to count how many ratings there have been.
Tim, I think their might be an issue with workflow involved in your photo album adding incident. I will investigate. There are two possible solutions and I will probably enforce both, hopefully having it done by tonight.
Tim, where specifically is the apostrophe problem? I dont see it in your vehicle name "doax's paseo," but I know why it is happening so let me know where and I will get it.
Ooops, you are both Tim...Tercel Tim, I actually dont know what this problem is, but I will try to solve it tonight.
You try to make something better and it all breaks!!
Also, I started working on a stats feature for the garage. You can see it in the sidebar: 1997 Toyota Paseo "Daox's Paseo" - GreenCarAlbum Stats are fun to me.
Anyway, let me know if anything else is borked or you desire, and I will get on it!
Old 07-09-2009, 10:16 PM   #76 (permalink)
Dartmouth 2010
SVOboy's Avatar
Also, Prius Tim, one of the movies you added has a broken url. :'(
Old 07-10-2009, 07:14 AM   #77 (permalink)
Dartmouth 2010
SVOboy's Avatar
Hopefully I have solved many of the problems, except for the text field size problem. Will get to it soon I hope.
Also, made commenting a bit better and fixed some other little buggers
Old 07-10-2009, 09:13 AM   #78 (permalink)
You can see the apostrophe problem if you click 'garage' and look at the comments section of the Prius.
Hmm, I'll have to check the youtube video at home. I just pasted in the ID from the link here on EM.
Old 07-10-2009, 09:17 AM   #79 (permalink)
Dartmouth 2010
SVOboy's Avatar
Prius Tim, I believe I solved the hybrid situation.
Currently pondering fuel logs. Clearly, they would be good to have, but just making new ones and expecting everyone to transfer/update another set of logs seems dumb. I would like to have them work in harmony with EM. I am thinking how.
Would people like that? Having them update to/from EM constantly without extra input?
Old 07-10-2009, 09:44 AM   #80 (permalink)
Having them linked to EM would definitely be ideal.
