Old 08-03-2010, 02:57 PM   #11 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Originally Posted by wyatt View Post
Interesting, I think we just crossed 115,000 miles, so the transaxle oil change would be a good idea... Are you proposing that we have a transaxle oil change date? Do both at the same time? I would be up for it!
In this HEAT! I'll be doing mine at the crack of dawn on Saturday or Sunday morning . . . or do you have an air conditioned garage? <GRINS>
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
Old 08-03-2010, 03:13 PM   #12 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
No air conditioned garage at my house... I would be up for an EARLY morning change, or if it really doesn't take too long, an early morning change (I don't have AC in my daily driver, so the heat isn't as much of a detractor to me). If my car would have to cool significantly before the oil could be changed, I would even be up for seeing how it's done.
Old 08-03-2010, 03:16 PM   #13 (permalink)
What oil do you recommend replacing it with Bob? I haven't done this on mine either and I'm around 65k.
Old 08-03-2010, 03:29 PM   #14 (permalink)
Engineering first
Use the OEM Type WS, the Toyota brand. I've looked at different alternatives and even tested Amsoil ATF. Toyota Type WS has values more like aircraft turbine engine oil:
2003 Prius - Cold Weather and Transaxle
The last two columns are the Type W oil and the results from the first, 60,000 mile change. Since then, the owner has gone through two more and is getting much improved results.
The viscosity numbers at 100C and 40C are the tell of a quality oil:
24.6 cTs @40C
5.5 cTs @100C
I've looked and this stuff is great. Heck the Type T-IV (what I'm supposed to use in our NHW11,) wears down to the Type WS starting viscosity. But when Type T-IV has worn down to that level, it has become a 'lapping compound.'
Bob Wilson
The Following 2 Users Say Thank You to bwilson4web For This Useful Post:
Daox (08-03-2010), wyatt (08-03-2010)
Old 08-03-2010, 03:56 PM   #15 (permalink)
Do you have to go to a Toyota dealer to get it? I haven't looked for it before, but am assuming that it isn't available at Wal-Mart...
Old 08-03-2010, 04:40 PM   #16 (permalink)
Engineering first
Yes, Type WS seems to be only available from a Toyota Service Center. Double check with Hobbit's write-up on the amount for the NHW20. You'll also need a large, metric, hex driver.
Bob Wilson
Electric water pump Gregte DIY / How-to 96 05-08-2022 03:49 PM
Heat Pump Temp Lockout Settings to Gas Backup RH77 Saving@Home 3 03-11-2012 09:41 AM
Keeping Engine Coolant Hot Raysp30 EcoModding Central 18 12-08-2011 07:57 PM
My favorite hand air pump NeilBlanchard General Efficiency Discussion 6 03-02-2011 01:24 PM
Hydraulic Hybrid Vs. Electric Hybrid jason.thompson EcoModding Central 20 09-15-2009 07:39 PM
