Old 04-28-2009, 08:06 AM   #1 (permalink)
Mazderr - '96 Mazda 626 LX
JETRRR - '01 Volkswagen Jetta
90 day: 44.3 mpg (US)
Larger tires with ScanGauge
Hello,
Is there a way to adjust the settings for a larger tire diameter?
Old 04-28-2009, 10:56 AM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
repete -
Welcome to EM! In the setup section you can set the speed +-%.
Here is one tire size calculator you can use to figure out the % difference from OEM :
Tire size calculator
CarloSW2
American Solar Energy Society
Old 04-28-2009, 11:23 AM   #3 (permalink)
90 day: 51.82 mpg (US)
Yes - it's in the "MORE" menu. The offset for your speedometer/odometer is under the "SPEED" option.
I have mine adjusted because I'm not running the OEM spec tire size for the transmission in my car (though I swapped transmissions, not tires).
With your larger tires, your speedo/odo will be reading low, so you'll have to use a positive offset in the ScanGauge to compensate.
Old 04-28-2009, 12:31 PM   #4 (permalink)
Excellent!! Thanks for the info.
According to the calculator my new tires will be +3.9%
Old 04-28-2009, 12:38 PM   #5 (permalink)
You're welcome.
I think the SPEED offset limits you to integers, but luckily 3.9 is pretty close to 4.
Old 08-06-2009, 08:03 AM   #6 (permalink)
Relevance is irrelevant!
bluetwo's Avatar
CR-EX - '12 Honda CR-Z EX
Send a message via Yahoo to bluetwo
Good info here. Now I gotta go try mine and compare it to a radar speed limit sign. Which isn't exactly a perfect science, I get it, but it's pretty close!
Edit: I went out and set mine to 7% and that fixed my Scangauge almost perfectly. I already knew I was off by about 2 MPH because I used several certified radar devices to check it. I had already known about the Speed adjustment but didn't know whether to go up or down and just feel like experimenting. I should've experimented though because it was a snap.
I'm talking about how I changed the Scangauge in my truck, not my Civic and the tire change was from 205/70/16 to 255/55/18, wherein I measured that I gained about two and quarter inches.
Old 10-05-2009, 02:32 PM   #7 (permalink)
White 4Runner - '98 Toyota 4Runner SR5
90 day: 23.21 mpg (US)
Grey Jetta TDI - '11 VW Jetta
90 day: 39.17 mpg (US)
Here is another tire size calculator that will allow you to compare up to 4 sizes to the original. You can also enter in the make, year, and model to find out the original size.
Tire Size Calculator - tire & wheel plus sizing
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
New Wheels & Tires trikkonceptz Success Stories 9 11-03-2008 02:05 PM
89 Metro XFI - MPG Decrease w/ Larger Tires SirKeats General Efficiency Discussion 15 09-02-2008 09:28 AM
Larger diameter tires = better FE? JV-Tuga EcoModding Central 16 07-12-2008 10:45 AM
