08-01-2009, 03:11 PM
#11 (permalink)
The skeptic in me says they wouldn't work for aero reduction.
But then it wouldn't be fair to say one way or another without a decent investigation.
08-01-2009, 03:26 PM
#12 (permalink)
eco....something or other
I am seriously thinking about taking a broom with VERY stiff bristles
and cutting them off so i can sandwich them between two bent pieces of aluminum with epoxy and trying that but it will be a lot of work so i will probably put it on a back burner and do some of the other things i have planned, like a v-shaped air dam.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
08-01-2009, 05:22 PM
#13 (permalink)
Yaris - '07 Toyota Yaris Liftback
lol that is NOT an aeromod...it is a wheel brush and water guard lol
08-01-2009, 08:13 PM
#14 (permalink)
My Goal: 35 MPG All Day
Well I think if you wanted to make front wheel skirts you need to get new front tires, same height but skinnier that the stock ones so that the flair your going to have to put on the skirts for turning can be closer to the vehicle.
08-02-2009, 01:37 AM
#15 (permalink)
air has to pass over and around an aero mod, not weave in and out through it
08-02-2009, 02:37 AM
#16 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
You can put 195 tires on 13x6 rims with a 42mm offset and 4" backspacing. You can also put 165 tires on 13x6 rims with a 42mm offset and 4" backspacing. Either way, you'll have nearly the same distance between the fender and widest point of the wheel rim. (Yes, it's a wheel rim, or outer most section of the circumference of the wheel.)
The gap between the fender and wheel is more a function of offset and backspacing than anything else. Skinnier tires won't cut it for you any differently.
08-02-2009, 02:53 AM
#17 (permalink)
aero guerrilla
I've seen those bristles on the front of city buses. I guessed they mostly are to keep water spray down, but the thought of using something similar as partial front skirts has crossed my mind. I do wonder, though, how it would work at highway speeds. Maybe just at the front of the wheel well?
08-02-2009, 02:59 AM
#18 (permalink)
The problem with the idea is the abstract of it overall. For the amount of time you'd spend trying to figure out how it would work, and whether it would work at all, you'd be hard pressed to not just install a solid partial skirt from the bumper and upper fender area to cover and slightly exceed the area in front of the tire.
08-02-2009, 10:22 PM
#19 (permalink)
Left Lane Ecodriver
I like the principle of the idea. I'm not sure bristles are good enough at blocking air, but what about plates of rubber or flexible plastic? Stiff enough that it doesn't flap violently in the breeze, soft enough not to damage a tire when you hit a pothole while turning. Maybe even partial spandex wheel skirts with a flexible wire frame for support. A wheel skirt doesn't need to cover the whole wheelarch, just the gap between the fender and the tire.
08-03-2009, 01:09 AM
#20 (permalink)
aero guerrilla
I think that the problem is that wind at highway speeds is as strong or stronger than the force it would take for the bristles to bend for the tire. This means that anything that isn't supposed to rub really hard on the tire will start to bend at 70+MPH. I think staying with the broom bristles is the best bet, I mean that they might be the most immune to bending at speed, since the air can go around them. A solid piece of material will have a relatively large area, so once it starts to flap or bend in the wind it's toast.
This idea is OK for buses and city trucks that don't exceed 45MPH.
