Old 02-01-2011, 04:16 PM   #11 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
Yes, but they won't have a soft beginning of travel and harden up very sharply like cut coils. In most cases, cut coils ride like crap. It works, but is far from ideal.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 02-01-2011, 04:41 PM   #12 (permalink)
Have you ever cut coils? Have you ever ridden in something with cut coils?
I have. I cut the coils on the Coupe. I have the exact same car with stock springs too. The lowered car does ride stiffer- totally expected. Part of that is the new struts on the lowered car vs the old ones on the stock car. But ride quality is still quite acceptable to me; I don't feel it was excessively compromised. But above all I don't feel that commercial lowering springs would perform better in any way, shape, or form.
Scared of the notion of cutting them? Do what I did: take the stock springs out and squirrel them away in the garage. Get a set of springs from a scrapyard for free or next to it. Cut them. Run them. Change them out if you don't like it. I never changed mine out...
Old 02-01-2011, 04:44 PM   #13 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
that's why i wish they weren't coil overs, they would be a lot easier to swap out, chances are i would be too lazy to swap the stock ones back in
Old 02-01-2011, 07:22 PM   #14 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Joe, you might look at some Jeep Liberty or Dodge Nitro forums (maybe dodgetalk or dodgeforum) and see what people are using to lower their vehicles. In the past, I have run lowering springs, which were stiffer, and that was fine in my book. For my truck there are lowering springs, drop spindles, or I can cut a coil (only 1/4 turn at a time). The best ride seems to be with drop spindles, but they are HEAVY.
My vote is for cutting the coils, at least for my truck. Yes, it might ride a little stiffer, but it is a truck!
Do what suits you, it is your vehicle...
Old 02-02-2011, 08:31 AM   #15 (permalink)
torch them
If you have a set of torches, and are good with them, you can heat the coil, and it will compress. Be careful If you do this wrong you will create a coil of scrap steel.
Another thought. Some manufacturers used different spring rates for different engines. There may be a stock spring available with a slightly different ap.
Old 02-02-2011, 08:45 AM   #16 (permalink)
pavement pounder
Smurf - '11 Honda Civic LX Sedan
90 day: 33.38 mpg (US)
I've got some factory springs that I took off my wrangler that I"ll give to you andyou can do whatever you want with them...
Old 02-02-2011, 11:25 AM   #17 (permalink)
Target 70mpg (UK) (58 US)
Clara - '94 Vauxhall Cavalier LS
Last 3: 51.88 mpg (US)
dont heat the coil, I cant remember what the metallurgy is but its baaad.
Cut it with the thinnest cutting disc you can find to keep the heat to a minimum. I dont own a car that doesnt have cut springs haha.
If its a subtle drop I doubt you'd notice a great difference. If you are going much lower youll need stiffer dampers. Dont cut so much that the spring dislocates.
