Old 01-03-2013, 02:04 PM   #1 (permalink)
Samurai transmission speedo drive
Hi all! New to this forum, but not to trying fuel savings from scams to things that actually work. Not scared to try new things, have flown behind a 3cyl turbo suzuki in a home built biplane. Current project is a suzuki 3cyl turbo in my 57 morris minor. Does anyone know how to get a speed reading from the Samurai transmission? Thanks. Roger
Old 01-05-2013, 12:37 AM   #2 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I don't have the answer, but there were 2WD Samurais.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 01-05-2013, 01:52 AM   #3 (permalink)
There were 2WD Vitaras, but I'm unaware about 2WD Samurais. BTW I've already seen some Vitara and Samurai owners work around bicycle speedometers when the stock one fails instead of replacing the stock sensors.
Old 01-15-2013, 01:30 PM   #4 (permalink)
Here in Canada we only have 4x4 sammys to my knowledge. There are 2wd trackers, but different bellhousing bolt pattern. I want the origional smiths speedometer to work, so the bike thing won't do. ??
Old 01-15-2013, 07:02 PM   #5 (permalink)
Wanting more for less
D.O.G.'s Avatar
Metric - '94 Honda Magna 250
Motorcycle
90 day: 69.83 mpg (US)
RedCelica - '94 Toyota Celica ZR
90 day: 35.97 mpg (US)
i30 - '12 Hyundai i30 Elite
90 day: 39.84 mpg (US)
i30-22 - '12 Hyundai i30 Elite
90 day: 39.22 mpg (US)
OK, I know nothing about the Samurai speedo set-up, sorry, I'm assuming it's an electronic one.
As a variation on CR's comment about bicycle speedos, how about a British motorcycle speedo drive?
My '55 AJS uses a Smiths speedo, driven by a self-contained gear drive clamped to the rear axle. That's a pretty standard set-up for bikes of that period.
I don't know if it would be possible to adapt such a gear drive to your car, or if the ratio is suitable.
If that doesn't work, how about an electronic speedo with the Smiths dial swapped in?
Old 01-15-2013, 07:54 PM   #6 (permalink)
Samurai speedo is mechanical cable. The problem is it runs off the back of the divorced transfer case. Therefore no drive from trans. I'm curious if the trans was used in other 2wd applications? Maybe a van or 2wd pickup? We didn't get them here, but I see a lot of them in NZ and OZ. There are several casting spots were it could go, so when I get it apart(needs bearings) I'll have a good look. Will check out the M/C tip as well. Thanks! Roger
Old 01-17-2013, 05:50 AM   #7 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
TeamSwift • View topic - Speedometer for a samurai in a mg midget
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 01-17-2013, 12:53 PM   #8 (permalink)
Thanks, I've been following that thread, but it doesn't allow me to use origional speedo.
