Old 02-27-2011, 12:41 PM   #1 (permalink)
new scangauge user question
I just got my scangauge the other day and hooked it up to my gas guzzling 96 silverado with a 5.7 engine, then today used it on my 2.2 litre sunfire. Boy does it ever take a wack of fuel to get that truck moving from a dead stop!! Anyhow, the truck is not my daily driver and is used mostly for towing, so it wasnt bought for economy.
On to the question...when I switched the unit over to the sunfire, I reset it to the defaults and went through the setup again. Took a ride into town and shut the car off for about 20 minutes and when I re-started it the avg gauge was now showing 0. Should the avg gauge not hold its memory, or does it reset to 0 whenever its shut off? It seems to me that when I had it in the truck the avg gauge memory was held, but I could be wrong.
I'm sure I'll have a few more questions as I get into this more.
Thanx!...Dan
Old 02-27-2011, 04:14 PM   #2 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
The AVG gauge resets to zero after the ignition is off for a set period of time - either 90 seconds or 3 minutes. That's because AVG is your current trip mpg, and the developers of the SG set it up to reset your trip mpg, distance, and fuel consumed after an engine shutdown.
The SG still maintains day and tank parameters in memory, but current trip parameters disappear. The SG's competition, the Ultra-gauge, takes the opposite tack, and maintains trip parameters until the user resets the trip.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 02-27-2011, 10:16 PM   #3 (permalink)
Knight - '07 Chevy Cobalt LS
Chevyteg - '95 Acura Integra LS
compare the gph at idle for the silverado vs the sunfire. Its immense.
Old 02-28-2011, 09:23 AM   #4 (permalink)
Thanx! Based on this I took the avg trip value and have it displayed as an xgauge
Old 02-28-2011, 11:57 AM   #5 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
Clock setting
One thing to look for is the clock settings being erased. Myself & someone else here had noticed that the clock would read 12:00 after a while on our GM trucks. It would only due it some times. I think it had something weird to do if the radio was left on or not. I have taken to leaving my radio on when the vehicle was turned off. It seemed to have "solved" the problem. I don't know if it will affect your other GM product or not.
Don
