Old 05-24-2014, 04:54 PM   #1 (permalink)
Retro-tech:Mechanical advance==>Programmable ignition
"Black Box"
Is It Possible To Combine Performance And Good Mileage? It Is With CB Performance's New Easy-To-Install Electronic Ignition System.
Even though this is on the HotVWs website, and in the current issue, they say
This unit will work with either 4-, 6- and 8-cylineder engines, and the kit comes complete with a 7-foot Flying Lead harness (allowing a variety of mounting locations, such as behind the rear seat), easy-to use Windows based software (XP, Vista, 7 or 8), and all electrical terminals and serial cables (some computers may require a USB to serial adapter).
That it appears in HotVWs explains the "either/and" mangling of the first sentence, and the Windows dependency needs to be fixed right now.
Here's a map for the Bosch 009
According to CB, the Black Box has a 21x21 spark table, and is good for up to 10,000 rpm. It incorporates a 5 Bar Map sensor, allowing boosted timing control over 40 psi. It also has an internal low and high end rev limiter (nice feature!), and will connect to ignition points, aftermarket ignition modules (such as Compufire and Pertronix, MSD distributors, and CB’s Magnaspark Ready-to-Run and Magnetic Trigger distributors). Most aftermarket ignition boxes, such as the MSD 6AL, 7AL, Summit and Mallory are also compatible.
I don't understand about the Map [sic] sensor. Surely http://en.wikipedia.org/wiki/MAP_sensor‎ I'm running the Magnaspark distributor they mention. It has a billet housing with Ford components. I trust their parts more than HVWs writing. Still...
For example, with our settings we cruised along at 3,200 rpm (approx 70mph) with the timing at 45° for maximum mileage, but the moment we stepped on the throttle the vacuum dropped, and timing dropped with it to 30° to prevent detonation — the best of both worlds! And the second mileage test, over the same highway and at the same gas stations, proved that the engine liked it, as it improved to 31.66mpg, an increase of 3.43mpg, or 12.15%.
Old 05-26-2014, 08:57 PM   #2 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Interesting. I would not try it without being tied to or adding a knock sensor. Not too hard, I've added these before when tuning Engine knock detection and indication for all vehicles
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 04-03-2016, 10:54 PM   #3 (permalink)
Zombie thread. I noticed it while looking or something else.
The CB Performance billet distributor is gone. It was not the black box, just a Hall effect sensor in a custom housing. It cost $350 new, after two years, every steel part inside was badly corroded and the sensor had fallen into pieces. CB Performance said the corrosion was "due to ozone. They all do that."
By the time it was repaired and back in the car, it was up to ~$800 total and obviously inoperative. So I'm back to an 009 and Pertronix with a thousand dollar learning experience.
