Old 07-20-2009, 10:00 PM   #1 (permalink)
O2 sensor
Hi, I'am a new member to this web-site and have a question for everyone that might have done this to their suv. I have a 08 hyundai santa fe gsl with the 2.7 engine. I'am trying to improve the mpg. I have removed the first muffler and left the 2 rear mufflers. Have increased my in town mpg by 3. My next step is to put O2 sencer extenders in to raise the tip of the O2 to top part of exhaust pipe. This should make the ecu , lean to some extent, my gas useage. My question to the members , will this change the factory perminters on the O2's enough that it will cause the ck engine light to come on? My friend did this on his lod ford van with a 351 v8 and his mpg went from 13 to 18. Looking forward to any info that would help. Thanks
Old 07-20-2009, 10:31 PM   #2 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
How does spacing your oxygen sensor get the engine to run lean?
I do know that running too lean increases your emissions.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 07-22-2009, 10:37 PM   #3 (permalink)
Smile 02 senser change
Orange4Boy, thanks for the question. By raising the 02 tip this will make the gas ratio reading lower. Computer on car should adjust your fuel useage to a lower reading, which means better mpg.
Old 07-23-2009, 06:04 PM   #4 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
I understood your original description but I want to know why the readings would be lower.
Why do you get a lower reading by offsetting the o2 sensor? Temperature difference? More oxygen at the pipe wall?
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
My Kingdom for a NOx Sensor cfg83 EcoModding Central 19 08-25-2010 06:55 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
O2 sensor? bikin' Ed Off-Topic Tech 13 07-11-2009 12:14 PM
O2 Sensor problem Need help! Curly1 DIY / How-to 1 05-23-2009 06:50 PM
