Old 05-05-2008, 08:06 PM   #1 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Kammback design
Without breaking out the calculators and running to your local windtunnel for specific testing I have a vague question about Kammback design.
If you build a Kammback that compliments the sloping roofline of your car, like my Vibe, would you end it at the same point that the rear bumper ends to make a sharp 90 degree line from top to bottom? Most examples I have seen of Kammbacks end ubruptly in order to achiece that flat back look.
Just need some advice before I bust out the wooden rods and fleece for fabrication.
Thanks ..
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-07-2008, 06:07 PM   #2 (permalink)
Kammback and the guillotine
The beauty of the Kamm roof is that you can chop it (truncate ) anywhere you like.Up to a point,the longer it is the better, as it is allowing a deacceleration zone for the air to regain pressure so when it does break away from the car,the wake is at a higher base pressure with less drag,however as others will say "we don't live at Bonneville",so as reality intrudes,we're faced with making some practical considerations.For the Vibe,you can end the roof wherever you like,and a vertical chop is just fine,as this was Kamm's intent.Bare in mind though, that the shorter the roof,the smaller the benefit.Since the Vibe is a "wagon-back" its sides are also converging in with the extension,which allows the top and side air streams to meet at closer the same velocity so as not to crash into one another,forming power-robbing eddies.
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
wheel airdam - deflector - strake? design questions lunarhighway Aerodynamics 14 04-02-2009 12:45 PM
Design competition: hybridize the Tuk Tuk (auto Rickshaw) MetroMPG EcoModding Central 4 02-07-2009 03:23 AM
Partial Kammback prototype tested - preliminary results MetroMPG Aerodynamics 8 11-28-2007 08:51 AM
