Old 10-08-2012, 04:43 PM   #11 (permalink)
So then he is using it to kill the engine when coasting or stopped then right? I assume he has a key ignition so he can start in neutral without having to put his foot on the break. I have a 2011 soul that is still under warranty so I don't know that I would want to risk voiding the warranty. Plus mine has a push button start so I can't start the engine while still moving. Any thoughts as to if it would actually void the warranty and if the soul you modified was a button start, how did that work out.
Old 10-08-2012, 09:06 PM   #12 (permalink)
Bertha - '16 Mercedes Benz Metris
If you can remove it when you go in for a service, warranty is intact. I'm thinking your 2011 kias are gonna throw a check engine light with the injectors circuit being open...
RETIRED
