Old 05-16-2014, 03:46 AM   #1 (permalink)
Do HX 5-wire oxygen sensors always turn white?
I saw this when I was working on my car:
I am not receiving CELs, except that awesome time that I started my car with the sensor disconnected, but that does not look good!
From looking around the web, this seems normal, at least when the car runs lean, in which case, isn't this actually good?
Old 05-16-2014, 12:23 PM   #2 (permalink)
darcane's Avatar
I wouldn't be worried about a white color... but there appears to be a heavy buildup of deposits. I've never seen that. Did you check the plugs? Anything odd there?
You only recently bought the car, right? Do you know much about the history of it? Any fuel additives? Any loss of oil or coolant?
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 05-16-2014, 12:40 PM   #3 (permalink)
I have a rear-main seal leak and one other, but they are very slow. In theory, that might be slightly better since I replaced the oil pan. I replaced the spark plugs and wires. I do not remember anything worrisome about them.
Old 05-18-2014, 09:33 AM   #4 (permalink)
I am fairly sure the O2 sensors at the exhaust manifold always turn white from the heat, mine were that color when I took them out for replacement. Downstream after the main cat, it was black from soot.
Old 05-18-2014, 12:42 PM   #5 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I would agree with this. IIRC, this is more or less what I saw when I replaced by O2 sensors a year and a half ago. My car is not LB capable, but...
