Old 07-11-2008, 04:00 PM   #1 (permalink)
Green Monster - '96 Saturn SL1
Send a message via AIM to WhenGrantAttacks
Green spark plugs?
I was looking around the internet and found "e3" spark plugs. This is supposedly what they do.
-Produces up to 12% more power, reducing fuel consumption up to 13% while cutting harmful toxic emissions up to 58%
-By reducing carbon deposits, your engine will run cleaner and smoother and last longer
Any of you guys ever try or hear about them?
Old 07-11-2008, 04:06 PM   #2 (permalink)
rjacob's Avatar
2017 Honda Civic LX - '17 Honda Civic LX
90 day: 39.92 mpg (US)
They don't sound too promising:
Don't count on E3 spark plugs to save you money on gas - AutoblogGreen
GreenCarMPG.com
Old 07-11-2008, 04:19 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Indeed, sounds like BS
Old 07-11-2008, 05:10 PM   #4 (permalink)
MR2 - '93 Toyota MR2 Turbo
90 day: 22.92 mpg (US)
Send a message via AIM to Blue Bomber
Yup, pretty much BS. If you're looking for the best spark plugs, try Denso Iridium Power. Iridium is a very strong metal, so tips can be made extremely small compared to copper or platinum. This results in a much denser spark that can ignite leaner mixtures than regular plugs. It also makes them last much, much longer. Average lifespan is about 40-60k for Iridium power, and long life (used in OEM applications) is up to 100K. Probably more under hypermiling. They're are a little under $10 each on eBay. These plugs worked wonders on my 86 Celica GT-S and 93 MR2 Turbo, making engine response quicker, and making the engine run smoother overall compared to new copper plugs. NGK also makes iridiums.
DIY - Spark Plug Indexing SVOboy DIY / How-to 40 05-21-2009 12:58 PM
Halo Spark Plugs..... Impulse EcoModding Central 7 06-26-2008 08:39 AM
Spark plugs Jason EcoModding Central 2 06-03-2008 12:46 AM
Would a different heat range of spark plugs help FE? Chris D. EcoModding Central 3 03-17-2008 08:03 AM
Halo Spark Plugs DifferentPointofView EcoModding Central 1 01-28-2008 11:13 PM
