Old 12-03-2013, 07:34 PM   #11 (permalink)
...beats walking...
...and Autmotive Yoda sez: "...may the force be with you (downward)..."
Old 12-04-2013, 07:29 AM   #12 (permalink)
Tire Geek
CapriRacer's Avatar
I think the original question wasn't about the Bernoulli effect or the Venturi effect, but why an inverted wing is more effective near the ground - and I think the answer to that question is that the further away from the ground the wing is, the more the effect of the wing ends come into play. When close to the ground, the vortices from the wingtips encounter the ground and provide a barrier to air migration out of the under wing area.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
Old 12-04-2013, 08:27 AM   #13 (permalink)
I had not ventured outside of 2D thinking on this topic until now.
Yes, this would seem to be an additional factor.
Aerospaceweb.org | Ask Us - Ground Effect and WIG Vehicles
McCabism: Front-wing ground effect
but the current emphasis is perhaps a consequence of the new technical regulations introduced for the 2009 season, which permitted the front-wing to be much closer to the ground.
Flying in the Ground Effect - Chuck's Overview - X-Plane.Org Forum
Ground Effect and Wingspan | Jetcareers
Old 12-04-2013, 02:52 PM   #14 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Vortexes form behind the wing.
They are, of course, the effect of what's happening with the air around the wing.
Old 12-04-2013, 06:06 PM   #15 (permalink)
axle
Great information, thanks to all.
I had an idea once where the rear axle of a car/truck would be foil shaped, and designed to produce down-force.
This assuming a smooth under belly for the vehicle of course.
I'm now thinking this idea could have wings, or at least inverted wings.
Morelli used the front and rear axle areas of the CNR 'banana' car to create downforce which would cancel the lift generated by the roof to achieve zero-lift.Exquisite!
