Old 03-25-2009, 11:57 PM   #1 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Larger than OEM Oil Filter ...
Hello -
WARNING: I have read that if you don't make a good choice, this could hurt your engine, so you takes your chances.
A long time ago a saturnfan MPG dude named cheapybob told me that he uses a larger-than-OEM oil filter in his Saturn S-Series. He told me that on his weekend racing trans-am, he picked up some HP by using a larger oil filter. On the idea that he would also get better MPG on his Saturn, he did the same. Recently I got around to trying this. I went to an indy auto-parts store, and got the Wix 51516 for about 7 bucks :
Wix Oil Filter part #51516 (Ford Focus)
Code:
Thread Size: 3/4-16
Height: 4.828
Outer Diameter Top: 2.921
Gasket Diameters
Number    O.D.   I.D.   Thk.
Attached  2.734  2.430  0.226
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=14/31
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 20
I matched up the gasket and thread specs to the Saturn oil filter :
Wix Oil Filter part #51348 (Saturn S-Series)
Code:
Height: 3.404
Thread Size: 3/4-16
Gasket Diameters
Beta Ratio: 2/20=21/37
Nominal Micron Rating: 19
From what I have read, the *theory* is that you can reduce your pumping losses, but I can't really tell if it helps. I was hoping to read that it had a better "flow rate", but the above specs look to be mostly identical.
It's only been about 1000 miles, but so far I'm happy with it. If I don't get an MPG bump, then I'm hoping that it's healthier for the engine on the theory that the greater surface area will catch more dirt. Here is a saturnfan thread that talks about using a bigger filter, if not for MPG reasons :
Bigger Oil Filter DOHC - SaturnFans Forums
CarloSW2
American Solar Energy Society
Old 03-26-2009, 12:46 AM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I used to run a longer filter, almost twice as long as stock, without issue but it was from the ams oil dealer and I didn't have a part number for it, so I lost out and went back to the stock size, if anyone has a part number for a larger filter for the civic vx I would like to know as I should change my oil this spring.
Old 03-26-2009, 07:25 AM   #3 (permalink)
Custom User Title
Daily Driver - '02 Pontiac Grand Prix SE
90 day: 18.45 mpg (US)
I always ran larger than stock on my protege. Did it help? who knows, but I know having more filter area allowed me to run synthetic for 5000 miles and not worry about the filter dying prematurely.
the real key it to find one with a similar bypass pressure. Too high or too low could (most likely will) damage your motor from not allowing oil through or letting particulates through, both harmful states.
Old 03-26-2009, 07:29 AM   #4 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Low rpm, low flow. If this is anything air filters, you would not see the slightest difference at low rpm.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 03-26-2009, 12:09 PM   #5 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
I run a ford 5.0 filter on the shadow, the big motorcraft fl-1a. It dwarfs the stock filter. On the capri I ran one for a 2.5 v6, its an inch longer.
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
Old 03-26-2009, 12:29 PM   #6 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
All my vehicles as stock use a 3387A filter. On all of them I have always used a 3980 filter instead, which is about 1.5x longer. It may or may not be better, I know I have never had an oil related engine problem. I just like it because it is way easier to get a filter wrench on it.
Winter daily driver, parked most days right now
Summer daily driver
Old 03-26-2009, 07:57 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
tasdrouille -
Originally Posted by tasdrouille View Post
Low rpm, low flow. If this is anything [like?] air filters, you would not see the slightest difference at low rpm.
Ok. So you are saying that this is really a performance mod that doesn't translate to eco-driving. Good to know.
CarloSW2
Old 03-26-2009, 10:09 PM   #8 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I run the FL-1A on my Metro also. See this size comparison.................
GeoMetroforum.com - got mpg?
Old 03-27-2009, 03:08 AM   #9 (permalink)
A bigger oil filter creates less of a pressure drop, so the filter will switch to bypass mode much less often.
But there are important things to consider... Whether the filter has a good anti-drainback valve (may not matter for some cars), and how the bypass valve works. Some filters have the bypass setup in a such a way that oil flows over the DIRTY side when bypassing, putting all the contaminants back in the oil. Even some Mobil 1 filters are like that according to someone on Miata.net.
Old 03-27-2009, 04:06 PM   #10 (permalink)
BMK 13 Ams Oil is what I use
My 03 Echo with OEM filter uses 3.3 quarts of oil. With the Dual remote BMK 13 with sub micron filter and large regular filter It uses 6 quarts of oil. I change the oil one every 3 years and it is not needed, I just do it. The picture sucks but you can get the Idea
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Article: Crude oil is getting cheaper — so why isn't gas? Frank Lee The Lounge 20 07-14-2010 01:06 AM
Larger oil filter for better FE? Gregte DIY / How-to 44 05-22-2010 11:12 PM
